FixYa.com
Tags:
Panasonic SC-AK300 CD Shelf System
No Disc (by 2 users)
posted by Texhubby on Dec 15, 2005
Unit displays "no disc" when a disc is inserted and will not play
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 14, 2008
my computer is only a few months old and it doesn't read a cd any more. what's up with that?
Best Solution
posted on Dec 18, 2005
FixYa! (100)
Texhubby
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
Kimi's solution would be valid for me if the disc would spin, but it is not spinning.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Kimi
Rank:Wiz Wiz
Rating: 80%, 622 votes
If you sure that the system supports the disc's format.. and it wont play other discs... try to clean the CD lens.
CD lens cleaning discs:
Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage?
I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer.
However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.)
As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Solution #3
Thanks for Trying (70)
Kimi
Rank:Wiz Wiz
Are you sure? as far as i know, It has to focus before it will spin...
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
Sony Mini Hi-Fi Component...
I have a Sony Mini Hi-Fi... Answer This...
Audio Shelf Systems
No sound at maximum volume
"my sharp portable... Answer This...
Audio Shelf Systems
Fisher MC720 with a Matsushia...
What size electrolytic is... Answer This...
CD Changer will not work
I have a 5 disk changer and it... Answer This...
Panasonic SC-AK300 Remote code
Seeking code to use with... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
