Question about Electrolux ERN2820 Bottom Freezer Refrigerator
Electrolux ern2821 What does the red switch do in the fridge part when it is lit up
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Electrolux EW26SS65GS0 Refrigerator. Temps going up. Red High temp alert and blue adjusting temp indicator lit. Suggestions?
Same problem for past month, tried replacing motherboard and today still showing Red High and adjusting....$500 so far and three service calls...what to do...food thrown out and good thing my garage is cool to store some stuff.....
Dec 18, 2010 | Electrolux Refrigerators
Dear Sirs, We have and Electrolux integrated fridge freezer. The upper part ( fridge) is not keeping things cold any more but the freezer is ok. Nothing wrong with door seals etc... We have turned...
ice build up is usually a sign of lack of airflow(possible fan). or failure in defrost. if fan is running something related to defrost. there are bimetals that need to be ohmed out and the heater as well. if you can comfirm these parts are good change defrost control.
Aug 01, 2010 | Refrigerators
Electrolux ERN2821: Faulty freezer door
check defrost element, defrost timer , defrost termination switch
Aug 07, 2009 | Electrolux ERN2820 Bottom Freezer...
Fridge in VW camper van
CHECK appliancesfactoryparts.com
Jul 26, 2009 | Refrigerators
Camper fridge ignites and runs on gas then fails
I beleive the thermocouple is faulty, this allows gas to flow once the flame is lit, but will also close the valve if faulty. Rateme
Mar 11, 2009 | Electrolux Refrigerators
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
May 28, 2008 | Electrolux Refrigerators
Electrolux ERN2820 Bottom Freezer Refrigerator Logo
110 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
