2000 Dodge Stratus Logo
Posted on Sep 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key wont turn to lock position for the steering wheel?
My key wont turn to the lock position for the steering wheel to lock what do i do?
  • Adam Kosose
    Adam Kosose Aug 28, 2016
    Try turning your steering wheel, some of the cars has a safety lock that will lock your tumblers in your ignition and the steering wheel which acts as an anti-theft systems. I would try turning your steering wheel to the left and right as much as you can which will not be much. Yes, I realize it seems a bit goofy, but I had vehicle that would not let go my key, but turning the steering wheel to the left and right and at the same time attempting to turn the ignition to the neutral position to get the key out was the only way to retrieve my key. It keeps people from putting the vehicle into Neutral and pushing your car away without the key.
Xenophon Liap
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 09, 2016
Xenophon Liap
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
4759
Points
21
No need to worry much about it. Just ask your local locksmith service providers like ours "Las Vegas nv Locksmiths".
Adam Kosose
Level 2:
Habit-Forming:
New Friend:
  • Expert 35 Answers
  • Posted on Jul 23, 2016
Adam Kosose
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
35
Questions
0
Helped
38046
Points
283
A
Anonymous
Auto trans must be in park if it is then I believe a relay or switch has failed. Check owner manual for possible fuse.
2answers
Key wont turn in my 2004 ford wind star
move the steering wheel most times that helps
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/david_4c166ba81493f541
2answers
Key ignition wont turn
APPLY BRAKE AND MAKE SURE STEERING WHEEL IS CENTERED. IF IT IS PARKED SO THERE IS PRESSURE ON THE FRONT WHEELS AND HOLDING THE STEERING WHEEL HARD RIGHT OR LEFT IT WILL MAKE THE KEY VERY HARD TO TURN.
My key wont turn either way seems to be locked
the steering wheel is in lock position. try to jerk the wheel to the left and at the same time turning your key
9helpful
2003 honda accord/ key wont turn,steering wheel is locked
To fix your problem, you have to turn the steering wheel either to the left or right as much as you can, then try to turn the key in the ignition. When the steering wheel locks, the key won't turn. By manually holding the steering wheel out of the lock position, the key will turn again and you're steering column will be back to normal.
2answers
When I put the key into the ignition and try to turn it it wont turn. The steering wheel is lock and when I try to move the steering wheel to find the "sweet Spot" to turn the key and start the car the key...
If your are turning the wheel to the "sweet spot" like you said, and you are using the right key, do you have a second key that still won't work? Then ignition lock tumblers are worn. You or dealer has to fix.
15helpful
The key wont turn in the ignition of my hyundai santa fe, its a 2005. The steering wheel lock is on and the wheels are straight, the key does not turn at all.
hi from uk please try this ? with key removed try gently turning steerwheel to the right if you feel a slight spring in steering ? hold on the spring and insert key it should work and release lockand turn ign on ? if steering is springing on left ? try as above the same method not unusual for steer lock to prevent turning key as the steering even in straight position ? the necessity to gently release load on lock is req'd to allow key to turn/unlock the steering lock from the steering column practice doing the above each time you fit key to unlock steering and tuning ign on to start hope this helps
The key want turn to start the car
exactly! The cylinder lock gets activated when the key is turned back for removal it releases a pin which will actually lock the steering wheel. Exactly opposite when inserted, First it has to release the steering lock otherwise the key simply wont turn. So it must have got stuck in lock position . Try jostling the wheel and rotate the key towards ignition position. If you hear a small click, that's the release of that pin and the wheel becomes free and the key can also be turned. This assembly must have got jammed or broken altogether and you might have to change the entire keylock..........sodeep
2001 mb clk 320, my ignition switch will not turn. screen tells me to remove key, but tires wont lock when key is removed(steering columb wont lock).
Hi there
I had something similar on my merc
but yours sounds similar.
the fact that you say the steering lock no longer works is very worrying, most times the key not going past position 1 is due to the steering lock being actuated and the pressure in it has to be released before the key will turn, you will have to go from lock to lock the find where the steering lock actuates when this happens follow my wiggle method of turning the steering wheel slightly when the steering lock is on the disengage it. ie keep trying the key whilst wiggeling the steering wheel.
hope that helps
2answers
Locked steering wheel
Try having someone rock the car frontwards and backwards, while you rock the steering wheel back and forth and try to turn the key - it sounds like you're jammed up hard against the steering column lock.
Please rate if this is helpful!
1helpful
1993 toyota camry ignition wont turn
the steering wheel SHOULD be locked if the key is not in the ignition and turned to the 1st position.  If you can turn the steering wheel more than an inch or so without the key n the first position,  the ignition switch (read: thingy you put the key in) is bad.
Sometimes you may have to move the steering wheel slightly to one side or the other to get the key to turn,  this in itself is not a cause for alarm. Try it and let us know.  If this doesn't work, you are probably looking at a couple hundred dollars parts and labor to get the switch/steering wheel lock mechanism fixed.
Please rate all solutions.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
