Question about Hitachi Televison & Video
Tv shuts down to standby - Hitachi Televison & Video
  • 2,712 Answers
You may have to replace the convergence IC.
It could also be due to faulty capacitors. You will have to open the back panel and take a look. Youcan make out which are faulty, because their caps will be swollen on top.Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacementsfrom your local electronics shop. If you are comfortable with this, you can usea pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.Once that is done, solder in the new capacitors carefully. If are unsure how todo this, try to get a friend who knows how to do this kinda stuff do it foryou, or get a qualified technician. Warning: If you do nothave a background in electronics repair, or are inexperienced, get a qualifiedtechnician to do it for you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
Posted on Sep 06, 2008
Why is my Samsung lcd tv stuck on standby
Theres probably a fault in the power supply board and the tv is shut down to protection mode
Sep 22, 2014 | Samsung LA40A450 40 in. LCD TV
Klv 32s200a
There are two things you can try. Press "Sleep" until you see "off" appears. If this doesn't fix the problem, go to the "Eco" settings and set "Power Saving" to "Off", set "Idle TV Standby" to off, and "Auto Shut Off" to "off". I hope this works for you.
Sep 20, 2013 | Televison & Video
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv shuts off go on standby wont power back up
make sure it is pluggen in all the way to the source of video or may need new cord
Nov 24, 2009 | Pioneer SD-P55A5K 55" Rear Projection...
Hi, tv set goes into standby,when you reset the picture is bright green for about 10 seconds and goes back into standby.
tv is drawing too much current and protection circuit kicks on and shuts tv down. try turning all screen controls all the way down. if that doesnt fix it, sounds like bad green picture tube. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
TV shuts down after a few seconds no picture comes on
I have LCD AKAI TV , It shuted down and no picture . Power never changes from red to green when I press remote control or standby button.
Oct 03, 2009 | Sanyo DP50747 50 in. Plasma TV
Lcd tv
What is the model number and mostlikely the set needs the software updated.
Aug 20, 2008 | Samsung Televison & Video
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Aug 14, 2008 | Sony KP-53HS10 TV
Shut down
Sorry, I do not know that set.
Feb 24, 2008 | Philips Magnavox 20MS3442 20" TV
Televison & Video Logo
102 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
