Question about Compaq Presario Notebook
Mic problem hi i have same problem.. my mic is not working ..for recording and..call.. and also when i use head phone..my laptopspeakers are not off.. so can i get solution from u..my model is c795tu.. plz send solution to my mail.. madhava.career@gmail.com and also send step by step..how to instal drivers..
    Scholar:
  • 65 Answers
This first file must be installed first before installing the audio driver. It is the Microsoft Universal Audio Architecture (UAA) Bus Driver for high Definition Audio
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
save it someplace then double click on it and follow the directions.
Next below here is the audio driver.
Conexant Smart Audio 221 Driver:
http://members.driverguide.com/driver/detail.php?action=download&driverid=1194857
You must be a member to download it which you can do for free.
It is in a zip file so after you download it you need to right click on it and select extract. Open the extracted folder until you see "Setup". Double click on "Setup" then follow the directions
Posted on Sep 09, 2008
The Mic will record, but when i plug in my headphones into the the mic in the front...it still continues to record when speaking, singing into it...but i cant hear the music (instrumental) in the...
This could be due to the output volume and monitor mix are turned too low. You can fix this by adjusting the input gain levels in the ASIO settings menu.
Apr 07, 2011 | M-Audio Producer USB Microphone with...
Tip
Studio Recording at Home; Part Deux
This tip, continuing the series of Home Studio Recording, focuses on the hardest part of accomplishing this feat: Drums.
A big sound killer on 'budget' recordings is poorly recorded drums. There is a remedy, though. If you have one set of drum mics, buy another (or borrow. This will come into play later, though).
If you have clips that hold them on the drums, great. With the two sets, you'll only use half of the clips. For the rest of the mics, you'll want stands. You'll need one stand for each drum, plus six.
The dual mics serve this purpose: To capture the sound of the whole drum. One mic for the batter head (the side you hit), and one for the resonator (the side you don't).
For the batter head, you'll use the mic clips, and attach the mics as you normally would during playing. For the resonator head, use the stands to position the mic directly across the drum, making a straight line from the top of the drum to the bottom. This will help eliminate any voicing differences, which can be a real headache.
For the bass drum, you'll need 2 stands. Position the batter head mic close to the edge of the head on whatever side is easiest to access, but is also comfortable for your playing style.
Aim the mic so that it is pointed at a midway point between the center of the head and the edge. You can experiment with different spots, but be sure to NEVER let the mic be directly in front of the head.
For the bass resonator head (the front one that everybody sees), position the mic so that it is a mirror image of the batter mic. Once again, this gets rid of voicing problems.
You have just miked your drum kit, but what about cymbals? That's where the other 4 mics and stands come into play. Those 4 will take care of:
Hi-hats
Ride
Overheads
For the hi-hats, you'll want to position the mic about 3-5 inches from the top, and 2-4 inches from the side. It's best to come in from the outside of the kit, so that you'll pick up a bit of ambiance (the rest of the kit, as well as some natural reverb). Point the mic at a point close to midway between the bell and edge of the hats. Too close to the edge, and you'll get a sound similar to banging trash can lids together. Too close to the bell, and there's too much high-mid noise that CANNOT be reduced with an EQ.
For the ride, follow the same instructions for the hi-hats, but add about 2 inches to the distances. Aim the mic a little closer to the center as well, so that the mic will pick up any bell hits. A good spot is 1/4 the distance between the bell and edge.
Now for overheads. These are the mics that not only record the cymbals, but pick up the most ambiance.
NOTICE: I haven't already mentioned it, but you do NOT want to record with the drum kit up against a wall, nor do you want it in the center of the room. For best results, use the midway rule (as with placing mics on drums and cymbals, place the kit midway between the center of the room and the edge, preferably headed towards a corner). This will reduce unwanted echoes in the room due to sound reflection.
You will want to place the overheads about 1.5 feet above the highest cymbal. Space them out so that the entire kit is between them, but be sure to keep them evenly spaced. You'll want to use the snare as a midway marker for the placement of overhead mics, since it is your loudest drum, and more likely to be picked up in the overheads than any other drum. This will also keep the snare panned center (you'll be panning the drums out to the left and right later on the mixer, but the snare and bass stay center).
These are some guidelines for setting up mics for recording drums at home. I hope that helps, and stay tuned for Part Trés of Home Studio Recording.
on Mar 13, 2011 | Music
I downloaded the quickvoice app onto my ipod touch- however it is not recording anything when i press record. do i need a mic or something?
yes my dear friend a small mic is available in market which you you need to plug in head set soket or you can try using a i phone handsfree which has a built in mic.
Dec 17, 2010 | nFinity QuickVoice® Recorder
Does it have a built in microphone?
Interrogate the information in your 'Recording' file
Plug your webcam in
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.- check both "Show disabled" and "Show disconnected"
Right click on volume graph and
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
May 20, 2010 | Gear Head WC330I Webcam
Microphone Help
Go to your sound properties and make sure it's not muted. Also, the recordind device should be the mic. Then open a recording application and give it a try.
Nov 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Mic not working with system
try to change your system just like the one that youve said that its working. it is maybe the system got the problem. or try this one, go to control panel see if your mic is working on your audio software application. set it to make it work by configuring like the volume or anything. hope that helps!
CHARCOIS
Aug 09, 2008 | Intel D845GVSR Motherboard
Microphone
buy an mic with head phones...they r cheap and they r best for web-chatting...
if u wnn record ur singinging and record conversations then go for an desktop mountable mic...it's clarity s good and also lil expensive....
ne other prob's do tell me..N plz do rate me
cya
Apr 14, 2008 | Gateway MX6920 Notebook
Loose Mic Head
Hi intel
Aahhh the joys of second hand gear. wow, the holes have been enlarged... may be that the original screws are not fitted to it also. OR less likely, mic may have become this way from years of being pulled in and out of a bag, with loose screws the whole time. It will rattle if the screws are a loose fit, can only suggest to you at this point try and get some new screws for it. or short on that (more drastic measure) to resecure the head of the mic with a small dap of clear nail varnish about each screw head. the varnish will hold well enough, but may present an issue getting the mic apart again, this depending entirley on how much of the stuff you have applied. Less is better :). other than that, there is not really a fix. Hope this advice helps you.
regards
robotek
Sep 06, 2007 | AKG C451B Professional Microphone
Compaq Presario Notebook Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
