Question about Hitachi Televison & Video
Hitachi natura shuts down to stnadby soon after turn on
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; youwill have to turn off front panelbuttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cablesfrom TV. Wait about 30 minutes and re-plug to AC power and redo the cabling.Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may haveallowed the power supply to cool. Weak capacitors often go out of spec whenthey cool, thus preventing a section of the power supply from firing upproperly again. There is a simple trick...just warm the back of the TV with ahair dryer for 5-7 mins after you have unplugged the TV. Look for the littleareas of holes in the back panel of TV. Use these as your guide at where to usethe hairdryer, but don't hold the dryer too close (say 5-6inches away). (Makesure the dryer is on High heat). If the TV doesn't turn on after you haveheated it up (like it tries to come on but then turns off) you need to unplugthe TV again, this resets it. And repeat those steps till it works. Resettingthe TV after it fails to turn on is the key. Also, just leave the TV on. Don'tturn in off. Since it is LCD, it doesn't take much power...only a few bucksextra a month for your utility bill.
4. A circuit board may crack about some of the largercomponents mounted on it. You can inspect the PCB's for fractures, and thenrepair them. It may also be poor soldering that has failed. I would be checkingfor these things first.
5. If you want to go in for a long term solution, you can easily replace thewhole power board or just change the faulty capacitors. You will have to openthe back panel and take a look. You can make out which are faulty, becausetheir caps will be swollen on top. Here's a sample pic of a bust capacitor (notsame model):
Check the specifications of the faulty capacitors, and get the replacementsfrom your local electronics shop. If you are comfortable with this, you can usea pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.Once that is done, solder in the new capacitors carefully. If are unsure how todo this, try to get a friend who knows how to do this kinda stuff do it foryou, or get a qualified technician. Warning: If you do nothave a background in electronics repair, or are inexperienced, get a qualifiedtechnician to do it for you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can. I am here at your service.
P.S. - You can rate a solution with one of fourratings as explained under (remember that at times a bit of to and fro dialoguemay be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on Sep 06, 2008
SOON AS I TURN MY TV ON IT SHUTS RIGHT BACK OFF
It sounds like a repair is required, but to confirm:
With this model, you can try unplugging from the wall for at least thirty seconds, then plug in and switch on. (That's if you haven't already).
If that doesn't work, there is a fault causing the power supply to self protect and shut down again. Repair will be needed.
Jan 05, 2011 | Hitachi P42H401 42 in. Plasma HDTV
Hi i have a somsung tv dlp. Shuts down as soon as
yes is one of your fans..
try to open the back of your TV and check that all of your fans are working if you see one is not. try to look at the part number.
here is a website where you can find a really good price..
its like $9.00
http://www.discount-merchant.com/HITACHI-Cooling-Fan-Set-Cooling-Fan-Set-p/1000959.htm
good luck!
Dec 27, 2009 | Samsung 50" Slim-Depth DLP HDTV
I bought a Natura Classica camera and I can't translate the Japanese manual. Does an English version of the manual exist?
The Fuji Natura Classica is a Japanese only model so no English manuals were produced.
The website below does give some translations though:-
http://moominsean.blogspot.com/2007/12/fuji-natura-classica-black-and-white.html
Jun 24, 2009 | Fuji Photography
Does there exist a manual for Hitachi Natura Tv, progressive scan on net?
Please intimate exact model number of your Hitachi TV to look for user manual. Model number would be written on sticker pasted at back of TV.
Jun 15, 2009 | Hitachi Televison & Video
Unlock zone Hitachi DVD player
I can't get my hitachi natura to connect to my dvd player using RCA plugs. I can't actually see how to switch to the av mode! Please help - small children going BONKERS!
Apr 13, 2009 | Hitachi DV-P745U DVD Player
Tv shuts off on its own
sounds like tuner isuues could be worng but thats what it sounds like to me or in that general curcuit somwhere...
Feb 04, 2009 | Hitachi 46F510 46" Projection HDTV
Hitachi 50EX12BX Projection TV Turns Off
Symptom: SHUT DOWN
Cause: CHECK I402-I601
If you need the full downloadable service manual for Hitachi 50ex12bx use the link below.
Hitachi 50EX12BX Download
Billyjones@fletchersite.com
Jan 17, 2009 | Televison & Video
Natura Hitachi 36in TV - Not turning on.........
Check the flyback transformer for cause of the odor . If it is a cap look for a cap that is buldging at the top of it . The flyback is the transformer with the red lead going to the picture tube . You might see it is cracked or a tiny hole in it . Good luck
Mar 04, 2008 | Televison & Video
Televison & Video Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
