Question about ASUS P4S800D-X Motherboard
Recognizing my sata DVD writer in bios mode
How can I make my sata DVD writer in bios mode recognized due to install a fresh copy of windows
How about a work-around?
(Your post is so old now that you probably figured out a solution . . . so this is for other readers)
I have the exact same motherboard, and a SIMILAR problem.
I have a PATA CD/DVD drive . . . so no problem there.
But I have a SATA hard drive, and the BIOS does NOT see it.
So when I boot from the WinXP CD, that is fine,
but then the install process claims I have no hard drive!
So how can I reinstall WinXP to a hard drive that doesn't exist yet?
Solution that didn't work:
So I knew the ASUS SATA driver (embedded in their RAID driver) needed to be loaded,
and TRUE, the WinXP install process gave me the opportunity (via F6 key) to install any
additional driver for a mass storage device. Great! So, with the latest driver on the floppy
from ASUS using their "MakeDisk" utility, I let the Windows install process read in the driver.
Well, it made the hard disk visible to the installation . . . sort of . . . but then it took me
to the Recovery Console (which I didn't want or need) rather than the Repair Install process
(and there was no "R" option available to initiate the Repair). So, gave up on that!
Solution that I think is sure to work:
Go to Ebay, and buy from Hong Kong a PATA to SATA adapter for about $7.50 including shipping. It is a great deal! And customer ratings gave HIGH marks, so the seller is trustworthy.
Make sure not to buy the SATA to PATA (the other direction), and also, I'd suggest buying the
version in which the little adapter card plugs directly (without a cable) into the PATA socket
on the motherboard, and then plug the SATA cable from it to the SATA hard drive (or the
SATA CD/DVD drive in your case). Connect the power jacks as needed. And presto!
You have converted the PATA interface to a SATA interface which needs no SATA driver!
The BIOS will see the SATA drive as a PATA drive (how clever!). After doing the WinXP
install or whatever, switch back to the way things were and save your adapter card for next time.
Posted on Jan 10, 2009
I replaced my harddrive in presario 2200 and now when i try to install windows it says it can't find the drivers
Try entering your BIOS and make sure your new drive is being recognized in the drives section and aslo make sure your drive is set to SATA not RAID . you can use AHCI mode also just it to set it to SATA then see if it installs. Also are you using a dvd to install it use a not scratched copy of windows DVD and install it fron your dvd/cd drive and set it to boot from your optical drive in BIOS as well.
May 14, 2014 | Compaq Presario Notebook
When i put some dvd disk in the drive it does not read but the light in the front just blinks constantly
Is your DVD-writer not recognizing any disk? If it so, the most probable case is that your DVD-writer's Optical Lens has been corrupted. Go for another new DVD-writer or try repairing your DVD-writer.
Dec 24, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I installed the DG43NB mother board and it is not recognizing my hard drive. I am running windows XP and I have installed the raid driver and I'm still not able to run it
Boot her up with a xp cd in the cd/dvd drive. She will take boot sector from there. Problem is that you mounted a SATA drive on an old IDE motherboard and used an additional PCI interface card that misfires
too fast or to slow to get xp's boot sector. Had such a case under my hands few months ago. This was the solution there.
Copied xp to a separate DVD and uses this to boot system, pc will only use boot sector from this and then use installed sata drive. Once fired up you can tempoerarily remove that CD/DVD and use for tasks.
Your problem lies in an older BIOS or older component. Maybe there is a later version.
BIOS flashing is tricky. Be sure to have backup before flashing. No experience leave it.
May 26, 2010 | Intel DG43NB Motherboard
System not recognizing dvd writer. new build. 2nd one I took the first one back thinking it was defective. HP dvd1270i dvd writer
Could be the motherboard's SATA connection is bad or not activated in the BIOS. I assume you have tested the SATA cable and verified that the SATA power connector is working. You may need to verify in the computer's BIOS that the SATA settings are on and correct. Do you have another SATA drive that is known to work that you can test in the computer to verify the SATA connection is working? Also some motherboards have a jumper on the board to disable and enable the SATA connection on the board. Verify that if there is a jumper it is in the correct position.
Nov 10, 2009 | Cars & Trucks
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
I just installed an LG 22x Internal Super writer DVD and my computer is not recognizing it. I have a jumper connecting the other drive. It is not picking up either one. Both open but nothing else. The...
I suppose your's is a SATA drive. Disconnect all the sata cables except for the Hard Disk and that of the Writer in question. Boot up and check if the drives works. If not take pains and try installing the drive in another PC (one of your friends'). If it still has the same problem check with where you bought it.
Jun 20, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Cannot reinstall windows xp because I don't have the sata driver to load as we indows instll fresh copy
how are u my frind ?now l have acer desktop computer duel cor 1.8gh hard disk 160gband ram 1gb .sata hard disk and sata dvd writer.so now install win xp .how to connect hard disk and install win xp
Apr 19, 2008 | Computers & Internet
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Not recognizing disc in D drive
Hi, well the short answer is NO. You cannot use DVD's in a CD Writer at all. So the simple answer is to get some CD-R and copy the files to them. OR get a Combo DVD/CD writer and install that as well.. and then you can use both..
Aug 06, 2007 | HP (178373133) (Refurbished) (178373133)...
ASUS P4S800D-X Motherboard Logo
510 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
