Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Help i have 2 problems : 1) in wireless it doesn`t auto alocate ip in lan works without any problem 2)on wireless conection it disconects every 3-4 min and i have to either reset the router or close and open again my wireless conection from my laptop i tried with diferent laptops and had the same result
  • Anonymous Dec 17, 2008
    I have the same problem: the router intermittently disconnects and disappears from the wireless networks list, and the only way to get it back is to restart the router. Seems to only happen when using P2P software. Upgraded firmware to the latest release and still no luck.
  • Anonymous Feb 05, 2009
    The laptop keeps on trying to get an IP number without success. Sometimes though it works.
  • 4 Answers
Wat is the make and model of the router?
try to upgrade the firmware on router to resolve wireless problems
Posted on Sep 11, 2008
I am trying to connect a panasonic blue ray recorder model number dmr bw 780 to the network i have followed the instrutions on connecting a lan cable to the unit and connecting the other end to a router...
This could be a few things. 1) Did you ever set p your router to only put out so many IP addresses? Meaning normally it is set for 50 IPs but a lot of people go in and set the IPs up for only how many computers are on it. This causes problems when people come over your house and connect their phones and such. 2) Some time when you put on new devices you have to reset your router. It has conflicts sometimes and all that is needed is a good reboot. 3) I don't know your unit but make sure you have everything setup to be auto on your device. Meaning auto ip, DNS and, Gateway on your player is set that way. 4) It maybe that your cable is bad. Just to make sure it isn't the cable try it on a laptop. Making sure you turn off your wireless on the laptop when you try this. Is the cable is bad the wireless will still pick up an IP faking you out thinking it works.
Hope this helps.
Jun 23, 2011 | Computers & Internet
Hello. I have wireless Router 802.11g / 2.4GHz. I have 3 PC i my house , but can only be on the internett with one of my computers. How can I set up my Router, so I can be on the Internett with all 3...
Sorry my anwser can be in spanish or english only.-
1.- All the conectivity devices, have a fisical address, and this is called "Mac Address", and is unique in the World.
2.- So,your wireless router have ones, and each computers too.
3.- The ISP (Internet Source Provider), only permit the Mac Address of the First computer only, and It know only this, so the Router Mac Address is unknow for they, and the rest of computers too.
4.- But, you can configure the firmware of the Router, so it show to the ISP the First Computer Mac Address allways, and this you can do in Items "Lan Configure" writing "Clone Mac Addres".-
5.- So, the ISP don`t see the Router MAc Address, always will see the Firts computer Mac Address, and the Router share the Internet Conectivity with other computers without problem.-
6.-For to configure the Router, in the browser you must write the followen Ip : 192.168.0.1 or samthing lake that, for this you must have conected your computer to the Router with an Ethernet cable with RJ-45 connectors.-
That is all.-
sincerely.-
Aug 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
Apr 02, 2010 | ASUS RT-N13U IEEE 802.3/3u IEEE 802.11b/g...
I have some problem with my D-link Des-1008D switch.I used it to connect 2 computer in my home and one cable form Internet shop.At that time, that Internet shop used manual IP to connect PC.And then That...
Does your ISP supply _one_ or _two_ IP-addresses per account?
On each computer:
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
What "IP-address" and "gateway" do you get for each computer?
No, a "driver" for the switch is not necessary, and will not help.
Instead, buy a "router" (with or without wireless capability), and rewire your network:
Cable-modem -> Ethernet-cable -> WAN-port on router
LAN-port-#1 on router -> Ethernet-cable -> Computer #1
LAN-port-#2 on router -> Ethernet-cable -> Computer #2
Turn the cable-modem off.
Turn the cable-modem on.
Turn the router on, to get one IP-address from your ISP.
Restart each computer, to get new IP-addresses for each computer.
Within the web-browser on each computer, disable "auto detect proxy".
Nov 16, 2009 | D-Link DES 1008D (DES-1008D) 8x10/100 Mbps...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Problems with IP address
Possible three (3) solutions:
1. Purchase and install a PCI LAN card (NIC) inside your "old tower". Should not be that difficult using any available PCI slot. Most would be auto detect/install by Windows (XP) or should come with a driver CD;
2. Use a USB to Ethernet adapter/converter; and/or
3. Use static IP address for the tower Same IP add (+1 on the last digit, same Subnet Mask, Default Gateway and DNS (if any). Should you need additional information on this method you need to post back details of your modem (brand/model, normally in a sticker underneath) so we can determine if it will allow simultaneous connection on USB & LAN.
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
133 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
