Question about RCA RS2620 CD Shelf System
No audio output.
All functions work but there is no audio output to speakers or headphones.
  • Walter Spadacini Jun 15, 2008
    all functions work but no sound at all.
Changer q 401 r?gulateur
Posted on May 31, 2007
The power supply electrolytics (C512, C513 & C514) and are a bit underrated. Recommend replacing them with 50 volt capacitors and placing an extra 2 in the vacant places next to C512 and C513. Replace C514 with a 2200uF 35V capacitor. Finally remove that resistor bridging F505 and place a 3amp 5x20mm fuse with holder clips for safety. That should stabilize the whole system.
Posted on Jan 01, 2006
IC 401 on the main board may be defective.
Posted on Dec 24, 2005
    Novelist:
    Champion:
  • 277 Answers
Most bookshelf systems rely on plasitc spring clips (or locking clips on some other models), on both the back of the main unit and speakers, to grasp the ultra-thin speaker wire. They could have easily pulled out of the clips if it was moved. As you check your speaker wires, make sure that the insulation on the wire is stripped far enough to not interfere with the wire in the jack. If the wires are good, check your input source to be sure you've selected CD, radio, tuner, or AUX. You can cycle through these options by using the source button. Make sure the mute is not engaged.
Posted on Dec 15, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
My laptop's audio software is installed correctly. it is working well in headphone but when i unpluged the headphone leaptop original speaker is not working
the problem is likely your speakers. consider the extension speaker or speakers use the function bound to perform troubleshooting
Mar 09, 2012 | Dell Computers & Internet
I dont have sound in my pc.i dont know where to fix my problem
If you sue external speakers or headphones, follow these instructions. If you have a notebook computer & are using the onboard speakers, skip to the *Windows section below.
You can start by checking your speakers, if any. Make sure they are powered on and functional. You may also want to test there speakers on a different computer just to make sure.
If the speakers work on a different computer but YOURS still does not have sound, try a known-working set of headphones. Make sure the jack is seated correctly as it may be loose.
*Windows:
Check the volume controls on in Windows. If windows does not have any volume controls, then chances are, the sound drivers are not installed. Check your computer manual to find out what model it is, then visit the manufacturer's website to download the appropriate drivers and software for the sound card.
Note that if you have used external speakers or headphones anytime before this issue started, you may have to re-plug the device & unplug it again & allow Windows to detect that it's unplugged (for HD-capable audio devices in Windows Vista or 7).
If you do have HD audio in Windows Vista or 7, right-click on the volume control in the notification tray on the bottom-right corner of your screen and select "Playback devices"...
... then make sure you choose the appropriate output device (whatever it is that you actually use: Speakers, headphones, HDTV output, etc).
Aug 12, 2011 | Computers & Internet
Sony Home theatre system 7.2 Channel Muteki HTDDW-7500 Problem : No sound output from speaker. Power supply, Display & Channel Sellector all function in normal. I have test with Headphone plug-in to...
If headphones are not working when you have unit properly set to the input you are using then there is something seriously wrong with the receiver. Is the monitor button incorrectly on?
Aug 25, 2017 | Sony Audio Players & Recorders
Yamaha HTR-5930 has no audio to speakers because it indicates and is sending audio to headphones although no headphones are plugged in. Carefully manipulated contacts on headphone jack with no change. Am I...
No I don't think so . These are complex units . If your headphones work then is routing the sound to the output circuit then you should get sound out the output jacks. Are your speakers turned off or set to output to speakers b ? Give me more details at ledstiles@hotmail.com I'll try and walk you through it. Larry's Electronics
Apr 21, 2010 | Audio Players & Recorders
RCA RS2620 CD Shelf System Logo
243 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
