Question about Teac PD-D2681 5-Disc CD Changer
TEAC PD-D2681 Door opens and closes too fast. Disc, when possible to put in in a quick manner, is not recognized often.
    Champion:
  • 277 Answers
Hi door cant be fix without a pro(bad chip) take a can of compressed air with a narrow hose find the laser eye with light and clear it good luck
Posted on Feb 26, 2006
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
TEAC CD player jammed
I had the same problem in 2007: I removed the cover and manually encouraged the cd drawer to open. It has been working ever since.
Jun 12, 2009 | Teac PD-H500 CD Player
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
Unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
  1. Open the disc door
  2. Press Setup, Vol +, Vol -, Vol +, Vol - on the remote control
  3. Press < or > on the remote control to select the region code (255 is all regions)
  4. Press 'enter' to confirm
  5. Close disc tray
Hope this helps.
Miche
Jun 12, 2008 | Televison & Video
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
DVD PLAYER PROBLEM
Sounds like a common problem with this trutech brand. There are some possibilities. 1. Laser could be worn out, 2 it could be a bad cable coming from the laser. 3 The home switch for the laser to come all the way back to its "HOME" position could be bad. But usually if this is the case, the disc won't spin at all. And 4th, the spindle motor that spins the disc could be worn out. Causing the disc not to spin fast enough and thus causing an error. Let me know if you want to send me one of these anyone so as i can trouble shoot the problem further. Keep me posted and i hope this helps you out some. Thank you Jay
Oct 10, 2007 | TruTech PVS2119 19 in. LCD Television
Teac PD-D2681 5-Disc CD Changer Logo
198 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
