Question about Pentax Optio T20 Digital Camera
SD Card After taking holiday snaps, SD card said that it was full!!! but it wasn't . Then it displayed that the card was not formatted. We have tried reading the card through the computer but it says it is not formatted....... have we lost all our photos is there anything we can do.
  • simpo38 Sep 06, 2008
    Brilliant, could not download your first recommendation the free version, But I have viewed the photos so I know that they are still there. Many thanks
  • Anonymous Jan 06, 2009
    After turning camera on, display shows "memory card error." Purchased a new memory card and the same problem appears. How can this be resolved?
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Posted on Sep 06, 2008
  • Greg Cann
    Greg Cann Sep 06, 2008
    Thanks for the good feedback, it makes it all worthwhile!
    Best regards,
Scanner says "full"
Try formatting the SD card before taking photos. Use the camera Menu and select format memory card.
Feb 12, 2013 | Cameras
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Feb 12, 2011 | Nikon Coolpix L1 Digital Camera
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
Jun 29, 2010 | Polaroid DVF130 Camcorder
XD card setup
hey, were you able to find a solution? Im having the same problem! thanks
Apr 04, 2009 | Olympus Stylus / mju 1040 Digital Camera
Memory SD full
Can you put the SD card in an external card reader and see any files? Did you format the sd cards in the camera? You should never format the cameras sd card with a pc.
Apr 14, 2017 | Vivitar ViviCam 3746 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Apr 02, 2008 | Samsung NV3 Digital Camera
Unformatted sd card in xacti camcorder
I have one sd card HAMA 12 GB and my computer and another computer canoty read my cd card iI have so much photo and video and my computer sad o bytes. Why ? I have photo and video i don't like delete . my cd hama card is 12 gb
Sep 25, 2007 | Video Cameras
Pentax Optio T20 Digital Camera Logo
70 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
