Drivers for wireless and the LAN
The computer does not connect to the wireless internet and the network cable
  • 535 Answers
Can u give me the model no
Posted on Sep 06, 2008
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
I cant get this sylvania 7 smartbook , model # synet07wicv to get internet.
Dec 25, 2011 | Sylvania G-Netbook
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
Jun 11, 2011 | Computers & Internet
So I just got a Dell Optiplex sx280 that runs windows xp and can't connect it to the wireless internet at my house. The built-in driver is a Broadcom NetXtreme 57xx Gigabit Controller, and I don't...
Desktop computers do not usually have a wireless card installed. They will have a built-in LAN card that uses a LAN cable.
If you want to connect your computer using a wireless connection then you will need to install a wireless card in your computer and configure it to communicate with your wireless router.
Otherwise you can connect to your wireless router using a LAN cable.
Your wireless router may have built-in LAN ports and you can connect your computer to the wireless router using a network cable.
Jun 09, 2011 | Dell OptiPlex SX280 PC Desktop
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
I have a dir-615 router and have been able to establish a wireless network but cannot get the network to connect to the internet.what can I do?
I assume you have a cable or a DSL modem connectec by a LAN cable to the wireless router.
Have you checked you with your ISP to see if the connection yo your modem is OK?
Have you check the LAN cable from the modem to the wireless router is good and it in plugged into the WAN/Internet port on the wireless router?
Have you installed the latest wireless card driver in the computer/laptop?
For instructions on setting up the wireless router and the wireless card in the computer/laptop, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance please leave me a comment.
Dec 23, 2009 | D-Link DIR-615 Wireless Router
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless internet connection not found
i need driver for my laptop by name vostro 1500 ( minicard 1390
May 01, 2009 | Gateway Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
