Question about Toshiba 50H82 50" Rear Projection Television
Wavy Lines which clear up after being on for 10 minutes - Toshiba 50H82
We have the wavy line problem which clears up after about 10 minutes. I see that you have given some suggestions on what might be wrong with it, but do you have a ballpark idea on costs? In your opinion, is it worth fixing it or would you just buy a new TV? Thanks!
  • flamingo_q Sep 10, 2008
    The picture is very wavy and after about 10 minutes clears up.
  • jose salgado Sep 25, 2008
    I have the same problem. It's getting worse.
    Where can I find a new hyperboard to replace?
    What is the part number?
It will cost about $300 to fix. The Hyperboard has to be replaced. I had it repaired over 2 years ago and it works great.
Posted on Sep 25, 2008
Wavy virticle lines pink and pirple picture hard to see?
virticle lines left to right and takes a long time to warm up to see picture. clears a bit
Sep 22, 2010 | Toshiba 51H84 51" Rear Projection...
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Skyassoc
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
46'' Toshiba HDTV
It needs the Scan Converter Module repaired or replaced. It usually has dry capacitors that need replacing
Dec 14, 2009 | Televison & Video
Toshiba 50H82 has wavy lines in screen for about
this is a very common problem in a lot of Toshiba sets of this type----bad caps(filter capacitors) on the "Hyper" board---it processes all signals in the set---it will start out where it clears up after warmup and as time goes by it will take longer and longer to clear up----the board is no longer available and the only way to repair is remove the one in the set and send it out for rebuild---most of the time this costs 3-4 hundred parts and labor(not worth doing)
Aug 07, 2009 | Toshiba 65H82 65" Rear Projection...
Same Problem
sounds like the Hyper module as it can cause that type of symptom when the Capacitors are getting weak
Jun 23, 2009 | Toshiba 50HDX82 50" Rear Projection...
When I turn on my 50H82 it takes 10 to 15 minutes
I just did a repair on one of these. Check your picture-on-picture. If the the secondary picture is clear, chances are very good the problem is on the "hyper board". We d not replace the hyper board - we repair it. The board is very expensive and rarely, if ever, available. There are several parts in the module that need replaced, but these are definitely not user replaceable. They are very small surface mount components and even I have lifted a copper or trace or two doing these. It is tedious work but our repair bill was well below $300. It is also something I do not do in the home and taking it to the repair facility is a money saver. I did go to the home on this one and remove the board to the shop, however they only lived a few miles away so the service call was low priced. Hope this helps...
Feb 23, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Wavy lines when i turn on the tv
this is a typical hyper module replacement job let a tech do it.
not for the do-it-yourself type.
May 26, 2008 | Toshiba 50H82 50" Rear Projection...
Video Inputs
Bad hyper board = can be repaired by a skilled,qualified tech...T.
Oct 28, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
373 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
