Question about Yamaha HTR-5830 Receiver
Yamaha htr-5830 im new to the home thearter game and i just bought a new yamaha htr-5830. i crancked up the volume just as the movie started, i noticed it was at 18db, there was not sound because the movie hadnt started but as soon as it did the unit cut out and turned off. can you help?
    Scholar:
  • 124 Answers
The amplifier protection circuit is kicking in. There are a number of possible reasons. One is that you have a problem with your speakers or speaker wiring. Carefully inspect your speakers for any changes, and examine the wires looking for shorts or opens. If it isn't a speaker problem, then something in the amp is triggering the protection event. It could be thermal (something getting too hot). That could be due to bad air circulation, dust, or an electronic component failure. A second event would be DC voltage on the speaker outputs. This could be due to a bad capacitor, leaky semiconductor, or the bias adjustment (if it has one) that needs to be reset. A third event would be high current draw. That most likely would be due to a semiconductor that is about to blow. You should have this checked out. If you keep doing your override, you may blow out something that wouldn't otherwise fail. Or you can wait for something to blow, and then it would be much easier to find the root cause (just look for the smoke).
Posted on Feb 15, 2006
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
Posted on Nov 07, 2006
What gauge speaker wire does a yamaha HTR-5830 use?
I dont think you can get much larger than 12 gauge wire into the speaker terminals
Feb 28, 2013 | Yamaha HTR-5830 Receiver
Can I hook up wireless speakers to Yamaha HTR-5830?
there are wireless kits available, and most all yamahas have pre-amp outputs for all the channels
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Jun 04, 2010 | Yamaha HTR-5830 Receiver
I am trying to hook up my Yamaha Universal Dock YDS-11 for my iPod touch into my Yamaha HTR 5830 Amp but there is not where to plug it into. Do I need another type of cables to do this.
Hi, I'm afraid that your receiver doesn't support YDS-11. You can check it at yamaha site. This dock uses special cable and special connector on the receiver (which yours doesn't have).
So the only way to connect your iPod to receiver is via analog audio output (jack connector on the iPod).
Jan 29, 2010 | Yamaha HTR-5830 Receiver
Need volume knob
Contact yamaha they can probably send you one or look on ebay you might get lucky there.Or go to walmart and take one off of a display :)
Sep 19, 2009 | Yamaha HTR-5830 Receiver
Yamaha HTR 5830 sound and no pic? I get sound in both DVD and TV?CBL modes but no picture.
make sure that the yellow video jack is on the tv out on the surround unit and is plugged into the video jack on the tv. You may have to change the input on your tv to Video1 or Video2 to get the pic to come in
Jun 07, 2009 | Yamaha HTR-5830 Receiver
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
Setup
dvd and dish tv optical inputs from both dvd and tv if tv has opticl out or give optical out from hd receiver. or rc pins from hd or tv to dtv/cable input of yamaha
Jan 02, 2008 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 Receiver Logo
444 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
