Question about Acer Aspire 3002LCi Notebook
Fan I recieved my laptop from my uncle and the cooling fan goes on and off can this be fixed before I try and use this
    Sergeant:
    Champion:
  • 271 Answers
That's a normall issue...it works only if the proccessor gets heated up...and after it's cooled the fan stops working...Automatic process
_______________________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Posted on Sep 06, 2008
How to clean fan for acer aspire
You could try air duster or even buy a fan that goes underneath the laptop to help it stay cool.
May 07, 2012 | Acer Aspire 5551 Notebook
I hear noise coming from the back vents and I think it might be the processor fan. Is there a way to fix/clean it so that noise goes away and do I have to open it from the bottom? This is for Qosmio G25.
You probably need to replace the cooling fan, but you can try cleaning it out first. Get a can of compressed air or use an air compressor to spray pressurized air into the vent to spray dust out. If this doesn't work, you probably need to replace the fan. I actually found a guide for opening up the Qosmio G25 and replacing or cleaning the cooling fan. Check it out:
http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm
Sep 24, 2011 | Toshiba Qosmio G25-AV513 Notebook
I have an acer 5741G which my father got me last year. i have just installed one game in it. when i play the laptop gets heated too much(that too within 30 minutes) and i have to stop playing to cool it...
Overheating of a laptop can cause degredation of components and possibly system failure but generally it could be a very simple fix. Best thing to do is to go out and buy a laptop cooling stand for it. The laptop will sit on this stand, which has fans that will blow cool air into the laptop from it's intake below the laptop and this should help to keep it from reaching critical temperatures. I recommend a laptop cooling stand for anyone who owns a laptop as the one fault of almost all laptops is the intake is usually directly below the laptop, and when you rest it on your lap you end up choking out it's air supply allowing it to overheat.
Jul 20, 2011 | Acer Aspire One PC Notebook
Fan error
There is a good possibility that the fan is full of fluff. If you hold a vacuum cleaner pipe up against the exhaust of the laptop, that may clear the blockage.
Hope that helps.
Mar 11, 2011 | Fujitsu LifeBook® E8210 PC Notebook
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
A blue screen came up when i was trying to play my game and if i dont have a fan behind my laptop it will shut down my uncle said its my fans that they cant cool my laptop enough and that maybe the game...
Usually it's too things:
Heat or a driver issue...or both.
You should get some canned / compressed air and blow the dust out of the laptop. Make sure it's off !!!
If you still have the problem afterwards then you can check Toshiba's support website if there is an updated video driver for your laptop.
Let me know if you need any more help.
Nov 20, 2009 | Toshiba Satellite P35-S611 Notebook
Gateway M-6307 power dies on boot up (reaches widow screen dies)
Make sure that it must be charged. If you are sure, there might be a problem of overheating.
If you check, there is a CPU fan. Overheating might cause thie.
Use a vacuum to cool on the fan to make it spin manually, hmmm it actually started to work after that.
If not, let me know.
Thanks for using "Fixya".
Jun 18, 2009 | Gateway M6307 Notebook
Problem of frequently shutdown unexpectedly for m6810 laptop ........When fan starts after some temp. goes up to 53 C. it causes....
laptops/notebooks tend to overheat more quickly the desktop resulting in shut down, try a laptop/notebook cooling fan
Feb 27, 2009 | E-Machines M6810 Notebook
Power goes off
1. Your heat sink (keeps CPU cool) may have dust built up on it causing the laptop to overheat and shut down to avoid damage.
Try a can of compressed air ($7.00 Wal-Mart) shoot air in all the vents on the side and under the laptop (do this outside or someplace easy to clean up)
2. Your fan to keep things cool may be stuck (the cleaning with compressed air could fix that) OR it could be broken. When you turn on your computer SOME fans power up this will let you know if it works (some only come on when needed) if your fan does not come on at all you may need to change it. You can Google laptop fans to find a replacement fan and install it yourself.
Good luck My Computer Guy
Nov 13, 2008 | HP Compaq nc6000 Notebook
Acer Aspire 3002LCi Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
