Question about Aiwa AV-DV70 5.1 Channels Receiver
Speakers started buzzing.
Speakers connected to Aiwa Av-DV70 receiver suddenly started buzzing.
    Problem Solver:
  • 5 Answers
It sound like your getting AC noise, chances are you have some dried out capacitors
Posted on May 17, 2006
Does anyone know the part number for the volume control rotary encoder for an Aiwa AV-DV70U audio/video receiver? There are no markings on the component but the pc board is marked SW101. A schematic...
The EC16B24304 number above is a discontinued Alps part. I found an equivalent encoder from Taiwan Alpha available on Mouser.com, part number RE160F-40E3-20A-24P. It has the same footprint, shaft length and keying. It fits perfectly. It has a lower rotational force than the Alps encoder and 24 detents per rotation instead of a smooth feel, but it is perfectly acceptable. I just made this repair on my Aiwa CX-NA222 stereo, and I've got my volume control back!
Feb 20, 2011 | Aiwa AV-DV70 5.1 Channels Receiver
I have AIWA AV DV75. It turns on but no sounds. Would you tell me the solution if you have an idea?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-DV75-Receivers-manual/id/1076dj797/t/2/
Page 22
We can't make assumptions that all is connected and selected properly.
Feb 19, 2011 | Aiwa AV-DV75
My aiwa av-x200 click right off when I turn it on, Im thinking it is a blown fuse or something, anybody fixed any receiver with this problem?
The unit is going into protection mode. There is a fault detected in either the power supply or an overload on the output circuitry. Remove all connections to the amp (ie speakers, dvd players etc etc) Turn the unit on. If it still turns off the problem is internal and should be looked at by a qualified technician.
Feb 09, 2010 | Aiwa AV-X200
TURNING ON, BUT NO OUTPUT TO SPEAKERS.
Try making sure tape monitor is in off position. Also I assume front speaker button is engaged. Another option is that analog setting needs to be changed to digital if digital output
Apr 22, 2009 | Aiwa AV-D67 Receiver
Speakers connection
There shouldnt be a problem with that at all. The subwoofer needs to be self powered. The Yamaha has a "Subwoofer Output" on the back. Just connect it there.
Apr 04, 2009 | Aiwa Audio Players & Recorders
Speakers conection
U can use the system, but u will need a separate sub woofer amplifier if your amp doesn't have one.
Apr 04, 2009 | 2002 Chrysler Voyager
Aiwa AV-DV75
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
Jan 02, 2009 | Aiwa AV-DV75
AIWA receiver
This Protection activates if you hook up Unmatched Speakers i.e less or over impedance as required by Aiwa Amp. 2nd reason can be extra speakers attachment.
Aug 04, 2008 | Aiwa AV-D58 Receiver
Static comes from speakers
I think it's a grounding problem. Actually, it's a necessity for all audio-video equipments to get grounded properly. If you don't have a ground connection in your AC plug, your receiver will collect more and more static electricity. As a matter of fact, it decreases the sound quality that you can get from your equipment. I think that the effect of your reaction (slapping the receiver) isn't coincidental. When you touch any metal surface on your receiver (even while slapping) you condact the static electricity to the ground. I've had a same sort of problem with my receiver. Especially when I connected my laptop computer to the receiver, I heard an annoying distorted sound from the speakers. I found out that it was ground loop, which occurs when the negative (common) signal of the source coincides with the one of the receiver's. As a solution, I grounded my amp, changed all wires with new and shielded ones, and purchased an AC filter. Then, I got rid of the noise. I have to say that the AC filter (Belkin Pure AV Surge Protector, it also includes an AC signal filter)benefited me the most.
May 03, 2007 | Aiwa AV-D67 Receiver
Aiwa AV-DV70 5.1 Channels Receiver Logo
212 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
