Question about Samsung HLN467W 46" Rear Projection HDTV
TV won't turn on - "lamp" LED flashes
I need verification - a previous tech said I had an IC failure. I need to know which board to replace.
  • 6 more comments
  • anthony777 Sep 06, 2008
    Thanks for your assistance. I tried step 1 and saw the "TIMER" LED flashing on the front of the set, but now power. Already tried step 2. I will work on step 3. I make a visual inspection of the boards to see if I could see any fractures on soldering joints, but saw nothing suspect.
    Can I be reasonably assured that the main ANALOG board is bad? Or might it be the small board (filter?) attached sideways on the side of the set?
    Not any response after step 3 either. Where would I look first for bad caps? Is there a voltage I should be looking for into the analog board?
    I am all for the long term solution. When you are referring to the "power board" which board do you mean? I have a board labeled "speakers" and a board labeled "main" (which also has all analog inputs) and a very small board to the left (looking from rear of set).
    Sorry, I cannot remember the tech's name - was at work when I did the chat. I thought it would be on my profile, but isn't there.
    The "LAMP" LED flashes only twice.
    Regardless of whether I use the remote or the power switch on the side, I can hear the relay turn on to power up, but don't hear the startup chime. The "LAMP" LED flashes twice and then I hear the relay open again.
    I have opened the cabinet to see if any cables were loose/disconnected, without any success.
    I only see two flashes of the one LED (lamp) - this means the bulb is bad?
    Is there any other check I can do on the bulb before I purchase a new one?
    What is the possibility the ballast is bad instead?
    I ordered a lamp. Not sure how to put the TV in standby mode - didn't see it in the manual.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; youwill have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cablesfrom TV. Wait about 30 minutes and replug to AC power and redo the cabling.Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may haveallowed the power supply to cool. Weak capacitors often go out of spec whenthey cool, thus preventing a section of the power supply from firing upproperly again. There is a simple trick...just warm the back of the TV with ahair dryer for 5-7 mins after you have unplugged the TV. Look for the littleareas of holes in the back panel of TV. Use these as your guide at where to usethe hairdryer, but don't hold the dryer too close (say 5-6inches away). (Makesure the dryer is on High heat). If the TV doesn't turn on after you haveheated it up (like it tries to come on but then turns off) you need to unplugthe TV again, this resets it. And repeat those steps till it works. Resettingthe TV after it fails to turn on is the key. Also, just leave the TV on. Don'tturn in off. Since it is LCD, it doesn't take much power...only a few bucksextra a month for your utility bill.
4. A circuit board may crack about some of the largercomponents mounted on it. You can inspect the PCB's for fractures, and thenrepair them. It may also be poor soldering that has failed. I would be checkingfor these things first.
5. If you want to go in for a long term solution, you can easily replace thewhole power board or just change the faulty capacitors. You will have to openthe back panel and take a look. You can make out which are faulty, becausetheir caps will be swollen on top. Here's a sample pic of a bust capacitor (notsame model):
TV won't turn on -
Check the specifications of the faulty capacitors, and get the replacementsfrom your local electronics shop. If you are comfortable with this, you can usea pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.Once that is done, solder in the new capacitors carefully. If are unsure how todo this, try to get a friend who knows how to do this kinda stuff do it foryou, or get a qualified technician. Warning: If you do nothave a background in electronics repair, or are inexperienced, get a qualifiedtechnician to do it for you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can. I am here at your service.
P.S. - You can rate a solution with one of fourratings as explained under (remember that at times a bit of to and fro dialoguemay be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on Sep 06, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Sep 06, 2008
    Usually the faulty caps will be around the convergence IC . (This is located on a large heat sink on the main board, and will be hard to miss). However, if you find the caps here in good condition, look around the board. Like I said, you can distinguish a faulty cap from a good one by the bulge. If all caps look to be in good shape, you may have to replace either the power board or the convergence IC itself.
  • Swilin Sampson
    Well, it is impossible to say if the issue is with the power board or the main board without testing it first. You can get online support to diagnose and repair your set yourself and parts as well at the following link:
    http://servicemanuals.vstore.ca/
  • Swilin Sampson
    I dont think it is a faulty bulb or a problem with the ballast. Go to the link I provided..that should help you.
  • Samsung Master
  • 13,433 Answers
The lamp would indicate that you have a faulty lamp, if you want to make completelu sure I suggest you ask slinteriors. Il get you a link to him, he has over 25years of experience in this field.
From the information that you have given me you would need to replace the lamp, which was the previous tech?
  • Ekse Sep 06, 2008
    This guy will give you a 100% correct answer I'm completely sure.
    http://www.fixya.com/users/slinteriors
    use the ask me button on hes profile and use the free option, otherwice you may get a answer from another expert.
  • Samsung Master
  • 19,396 Answers
Depends on how many times the led flashes, who was the tech?
  • 2 more comments
  • Ginko
    Ginko Sep 06, 2008
    The expert was probably referring to the convergence IC, that is a part that easily blows, you cannot know if you do not test them.
    Describe the problem in detail and tell me how many times it flashes.
  • Ginko
    Ginko Sep 06, 2008
    3 blinks on the led on Samsung DLP is lamp problem, you have to replace the bulb.
    See the discussion here, there are also links to sellers.
  • Ginko
    Ginko Sep 06, 2008
  • Ginko
    Ginko Sep 06, 2008
    There is also a reset procedure for the lamp time counter, you can try this before replacing the lamp.
    Put the TV in standby mode.
    Using the original remote:
    Press one by one the following buttons,: Mute -1-8-2-power
    The television should turn on Service menu.
    In service mode you find Lamp Options for lamp hours count, reset it.
    If you do something wrong on service mode you can cause further troubles on your TV , be careful.
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have mitsubishi vs 60719 chassis vz9 will not power up error code 21 all standby voltages are good 5 fuses are good when plugged in led 3 flashes led stays on for 15-20 sec no relay clicking or any...
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Sep 17, 2008 | Televison & Video
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
I have a sony kds 60a2020. the lamp sensor light was flashing and no picture. i bought a new lamp and installed it and now all i get is red power light flashing three times. as much as i can tell am ...
A lot of these had problems with the lamp door; you need to remove the door and take a careful look at it edgewise---heat from the lamp can warp the door.
Notice the small plastic peg on the back of the door--when installed it engages a lever which is a safety switch so set cannot be operated with door removed.
If door appears slightly warped what I do is engage the lever (usually tiny and blue in color) and turn the set on.
WARNING: IF SET COMES ON DO NOT LOOK AT LIGHT FROM LAMP DIRECTLY. If set works with lever engaged you need to replace the door (EBAY has sellers with most of them) and DO NOT OPERATE SET WITH DOOR REMOVED OR REPLACE OUTER SHIELD AS HEAT FROM LAMP CAN DAMAGE THAT WITH DOOR REMOVED.
Before you rate this solution let me know if you have questions or what you find; engaging the lever will either rule the door out or confirm it is your problem.
SD TECH
Jul 09, 2011 | Sony KDS-60A2020 60" HDTV
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
The tv keeps turning itself on and off
Ur tv have a LED POWER indicator light and a LED light indicator LAMP flashing?Yes,this is a DLP Tv the lamp live is over,must be replaced it with a new lamp.No,LED light LAMP indicator flashing,than ur tv is a LCD or a Plama tv.Than ur power supply board is dead.Must replaced the power supply board to solved this problems.
May 24, 2010 | Samsung HL-P6163W 61" TV
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Samsung HLN467W 46" Rear Projection HDTV Logo
203 people viewed this question
Jerry Greenberg
Jerry Greenberg
