Candy 24 in. CD623 Free-standing Dishwasher
Problem for Candy 24 in. CD623 Free-standing Dishwasher
Candy nova cd112
By ljgowen on Sep 06, 2008
When I switch machine on, it will fill with water then then just stop and nothing happens this occurs on all program setting. When I reset the machine and try again it drains? Could the timer be o.o.o
Clarification Request
Posted by tresilla on Sep 06, 2008
fault may be that the circulation pump is not running. can you hear a low humming noise??
Same Problem
Feb 15, 2009
-   i have a similar problem, it works fine on the rinse and quick wash settings but on all others it starts but stops after the first rinse and the light comes on and flashes fast. any ideas?-   connorpooh
Dec 15, 2008
-   hi again. Circulation pump tries to start but stops and led on panel goes out and so on and on.I disconected capacitor from circulation pump from my candy cd112 and tested it with digital multimeter and it says no(zero) uF instead of 4 uF-+ 5%.So ill buy new one and see if its solved problem and post it.
-   mavid
Oct 29, 2008
-   My Candy cd112 runs for a short while and then just stops. When the door is held tightly shut it runs for much longer, in fact sometimes finishing the cycle if something is pushed against the door. This suggests a microswitch on the door catch to me, but I cannot find any spare parts list which sells such a thing for the cd112.-   Guest
Solution #1
posted on Oct 31, 2008
Not Rated)
ncs79r
Rank: Apprentice
Rating: 0%, 0 votes
I appear to have solved this problem. Firstly I slightly adjusted the door catch on the actual machine, the strong wire bit, outwards. Then I undid the screws on the top part of the door exposing the electrics of the dial and door micro switch. I noticed that the microswitch (the small metal part pushed in and let out by the plastic arm rotated when opening and shutting the door) was dirty or rusty. I sprayed a little WD40 on this and played with the door catch a few times. I then screwed everything back in to place and the machine works perfectly. Easy and quick and a lot cheaper than the £80 I had just been quoted by a service person to come and change the switch mechanism as he called it!
Was this helpful?
Yes
No
Popular Solutions for Candy 24 in. CD623
Questions and Unsolved Problems for Candy 24 in. CD623
Do you recommend Candy 24 in. CD623 Free-standing Dishwasher?
Answer
Answer
Dishwasher makes cracking sound and blows trip fuse, have cleaned pipes in sink and still it... (More)
Answer
open catch has gone floppy small spring has come off and I can't see where it goes
Answer
my dishwasher leaks from the door, but the seal is not broken
Answer
candy 623 dial stops during cycle and no heat at end to dry?
Answer
A candy cd623 that iv'e aquired causes the power to trip. This did not happen instantly but about... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Tulsa, OK
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
