We have the Arcticaire ADR4066 and have installed a cut piece of garden hose to use the direct drain feature. We got the unit yesterday (Friday, Sep. 22/06) and have noticed that instead of draining through the hose, the tank still fills up. The hose is connected to the nipple, as per the directions, but the water is still coming out of the hole on the opposite side. Are we missing something? Have we overlooked something simple? Thanks! I am having the same problem. Unit is brand new. I determined that the knock out in the direct drain opening was removed and that the hose was not clogged (somehow blocked although new). The unit still fills the bucket first and then shuts down. The instructions (which did not come with the unit and I downloaded from mfgs. website) gives no instruction other than to attach the hose. I assume you have to leave the bucket in place and the unit knows to drain via the hose if the knockout is removed and the hose is attached. Confusing.......in that this should not be a problem with a new unit, never previously operated.
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?...
(More)
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean? What is the optimal temp to eliminate humdity?
My dehumidifier has a hose that drains into a floor drain. After some time, it stops draining thru...
(More)
My dehumidifier has a hose that drains into a floor drain. After some time, it stops draining thru the tube and instead, the water container in the unit fills up with water. What causes this to happen, and how can I fix it. I've cleaned out the tube, as their is a film or mildew(?) that may prevent the water from going through the tube. The tube runs about 10 ft. to the drain. Anything else I can do to make this drain through the tube to the floor drain?
I have a Danby Premiere 30 pint dehumidifier. It has been running well for one and a half summers...
(More)
I have a Danby Premiere 30 pint dehumidifier. It has been running well for one and a half summers in our unfinished basement. I have it hooked up to a hose that drains directly into our basement drain. The water drains out of this hose, however there is also a slow, steady drip coming from the bottom right-hand corner (same side as hose hook-up nossle) of the machine. I have checked the hose (plastic surgical tubing), and it seems to be securely attatched without any leaking. Does it have to do with condensation? The weather has been fluctuating quite a lot lately (20 degrees Celcius one day and 3 degrees the next). Any ideas?
Danby DDR586R unit. Coils freeze up and unit does not go into defrost. There are two thermistors:...
(More)
Danby DDR586R unit. Coils freeze up and unit does not go into defrost. There are two thermistors: one on the evaporator coil aluminum fins, and one on a loop of the evap coil. need to replace thermistors? charles
Danby Dehumidifier Model # DDR557HE Serial # 0107030704369 --Does not collect water and cxontinues...
(More)
Danby Dehumidifier Model # DDR557HE Serial # 0107030704369 --Does not collect water and cxontinues to frost up
