Question about Apple iPod nano
File corrupted dear sir, i have an iPod nano (1st) and then when i tried to open it it displays a folder with a warning sign.. what should i do?
    Problem Solver:
  • 38 Answers
Hello,i have been reading about your problem,and i have forund a reason why this has happened.... The reason why it is showing this message,is because you have not put the correct file types on the ipod, (eg.protected cds,blank mp3s,corrupt audio files,or a unsupported file type....)
Thanks for your question,
have a nice day...
Posted on Sep 13, 2008
Unlock volume control
you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
May 20, 2010 | Apple iPod nano
When I try to adjust the volume on my Ipod Nano under Settings it is asking me for a code. How do I reset the code or find out what the code is? Is there another way to increase the volume, it appears to...
moz-screenshot-8.pngmoz-screenshot-9.pngthat is not a problem follow the steps below and if it doesnt work let me know i will assist you from there. unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Mar 16, 2010 | Apple iPod nano
How to unlock factory volume lock,i dont have the code
why dont you try this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Dec 25, 2009 | Apple iPod nano
How to unlock volume limit
Nov 28, 2009 | Apple iPod nano
I need the code to unlock the volume on my ipod nano??
well i cannot give you a code as it is set by the user. and unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Jun 10, 2009 | Apple iPod nano
Silver ipod nano third generation
this is not a problem. follow the guide below. quick method for all O/S
  1. Plug in your iPod and iTunes will open ( or open it youself)
Click "Get Info"
Click "Yes"
killall Finder
killall Finder
In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Jun 09, 2009 | Apple iPod nano
Ipod
unfortunately the password is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs.
Click "Get Info"
Click "Yes"
killall Finder
killall Finder
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to musictoo loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Jun 06, 2009 | Apple iPod nano
Iod scren displays a yeidl sign and folder file on the screen
Hi, As i understand you see a folder with exclamation mark on it...
So 1st you hav to try resting the ipod.... Try to press and hold the menu and the center button for approx 6 to 8 secs... then once you see a Apple logo release the buttons. this should work
Other solution would be restoring your ipod to factory settings by connecting it to computer and restoring it using itunes... then update the software as well
If not... try to connect the ipod to computer and then open Mycomputer....Right click on ipod.... then format it.... wait for the format process... then using itunes restore it to factory settings
This has to work
Reply if unable ot if you need any help
Feb 03, 2009 | Apple iPod nano
Apple ipod installaion problem
install th ipod software in your PC,, open it, load song to your library,, you can find that if you open your ipod software,. after that, plug you ipod to you pc, that will automatically detect and sync by the software,. to avoid corrupt of file in your ipod, always eject you ipod. thanks
Dec 21, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
