Question about Microsoft Xbox 360 Console
XBOX 360
WE CANT GET IT TO WORK RIGHT!
  • 3 more comments
  • jsha jsha Sep 06, 2008
    WE JUS BOUGHT IT AN WEN WE HOOK IT UP TO THE COLORED PORTS ON TV WE EITHER HAVE SOUND AND NO PICTURE OR VERY MESSED UP PICTURE WITH SOUND!
    THE CABLE HAS 6 PLUGS ON IT N WE HAVE TRIED THEM N DIFFERENT COMBOS NOT REALY FINDING THE RIGHT ONE !
    I HAVE EXPLAINED PROBLEM! BUT IM GETTING NO INPUT ON IT!
    ITS A SHARP. MODEL NUMBER 27C240.
    ANY IDEAS ABOUT WHATS WRONG?
    Sergeant:
  • 241 Answers
Hi if you can see my comment
The Cable is most likely the problem.. If you have tried other Devises using the same Video?Audio TV inputs.
I would TRY these STEPS .
1) Exchange for A new Xbox if this was from a Local Retailer
2) If it was a Refurbished Xbox and you purchased online or from a LOCAL VIDEO GAMES retailer.. ask for an Exchange and see if there is a fee for shipping it back (ONLINE)
3) Go to the store or a Lic. Xbox Retailer and Buy an after market Plug or a 3rd party " to test it" save the receipt and if that works then you know what the problem is
If you see my comment please ( rate) or post
Posted on Sep 06, 2008
    Genius:
  • 1,665 Answers
To connect your Xbox 360 console to your high-definition TV (HDTV):
  1. Turn off your console.
  2. If another AV cable (such as the component HD AV cable) is already connected to your console's AV port, disconnect it before continuing.
  3. Connect the HDMI AV cable connector to the HDMI AV port (not the standard AV port) on the console.
  1. Connect the other end of the HDMI AV cable to the HDMI input on your TV.
  2. Turn on your console. From the System area, select the appropriate high definition video setting for your TV.
Connect a Stereo Audio System with the HDMI Cable HDMI supports audio through your TV. However, you might prefer to connect Xbox 360 audio to a different audio system, such as a stereo receiver or amplifier. To do so, connect the HDMI AV cable for video and the included audio adapter cable for audio.
Note
If you have a receiver that supports HDMI you don't need to use the HDMI AV cable. Instead, you can simply run your HDMI cable straight to the receiver and then out of the receiver to the TV.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Sep 06, 2008
  • 2,071 Answers
Maybe the problem is the INPUT board of your TV is loose or crack or cold solder joint,this is the common problem of the TV input,to solve the problem you can do it yourself this very easy just open the back cover and look the input connection the COMPOSITE VIDEO and COMPONENT VIDEO board to re works or resolder the solder joint,so it will works normally again...
Hope this may help you;
Regards,
VOTIT
    Genius:
  • 1,269 Answers
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
  • Michael Galve
    Michael Galve Sep 06, 2008
    The XBOX 360 is really not sensitive to any type of TV. As long as you have the right connections on the back, that should work fine. Since you said you have tried all possible cable combo and none works, its time to test the xbox to a different TV just to isolate the problem. Give it a try using different TV.
    Genius:
  • 1,689 Answers
This can be color coded, specially if it is labelled "component" (green red and yellow) plus the digital audios white black and red. please check on the manual too since these kind of connections are illustrated in the handbook.
    President:
  • 2,712 Answers
This link should help you:
http://www.xbox.com/en-us/support/systemsetup/xbox360/accessories/hdmicable.htm
There are more selections from the panel on the left. Choose the one you want, and it will give you all needed info on the connection setup. Hope that helps!
If you found my solution satisfactory, kindly take a moment to "Accept" it..
Thanks.
  • 1,879 Answers
What's your TV's make & model?
  • Microsoft Master
  • 13,433 Answers
Hey,
Can you explain the problem you are haveing?
Thanks,
Ekse
  • Ekse Sep 06, 2008
    You need to connect all 6, if your tv has only 3 your trying to connect to composite video. you need to pruchase a adapter which converts the 6 cables to 3 cables.
    Thats the solution.
    You can accept my solution or if you have any other questions let me know. The guys in the shop will get you the right kind of cable. your xbox is perfectly fine! congratulations on the purchase its a great "toy".
  • 535 Answers
Can u explain what happening
Why can you just make were people cant hack because im hack right now
It is always good to have a very good password like this for an example . (!w3E44r%Y&uij>.,/:s%
May 10, 2015 | Microsoft Corporation Xbox 360 Live...
I cant look around in fallout 3 (right stick frozen), and my last save point was hours and hours ago. however the right stick works in pause menu and other games. what do i do?
What probably happened is your right stick was compressed when the remote turned on. Try turning the remote off and on, or un-plug and plug it back in. If that doesn't work simply save your game using the left thumb stick.
Mar 11, 2011 | Bethesda Softworks Fallout 3 for Xbox 360
Forgot password to unlock family settings on xbox 360?
I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settings Console settings Then device settings (The one with the blue screen)
Then go:
left trigger, right trigger, x, y, left bumper, right bumper,
left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
I hope that helps
Regards
Mike
May 27, 2010 | Microsoft Xbox 360 Console
What to do if the xbox cant read the disc
it may not be the right format. you can't play 360 games on the original xbox and to play and old xbox game on the 360, you must have a hard drive attatched.
Apr 28, 2010 | Microsoft Xbox Console
All hooked up right and i cant get xbox live worked befor but not now ?
if u hooked up the xbox 360 cord to the internet box then the internet might not be working
Feb 18, 2010 | Microsoft Xbox 360 Console
I cant get a valid ip address for my xbox 360
set settings to automatic
if that doesnt work open command prompt on your computer type ipconfig and hit enter
manually enter the ip and dns settings that come up
if that doesnt work google xbox 360 port forwarding
Nov 17, 2009 | Microsoft Xbox 360 Console
Saints row 2 loading problem
try and save the game to your Xbox360 harddrive(HDD) and then run it off that?
Sep 26, 2009 | THQ Saints Row for Xbox 360
Ace combat 6 flight stick controller
order a new controller or replacement parts of ebay....
Dec 24, 2008 | Namco Ace Combat 6 Flight Bundle: Xbox 360
Xbox 360
http://serviceman.site88.net/index_files/GameConsoles.htm
Jul 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
137 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
