Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Wassher
Problem occurred suddenly
On all water settings and all washing selections after pushing start the water runs into machine for about 1- 2 seconds, then the flow stops running while there is a humming sound at the solenoid, but machine is not filling. I checked the flow of water from the hose and the in line filter at hose connection to machine and all was normal.
Is this a solenoid problem, sensor problem or other....can I fix it... and
if I were to pour water into the machine would it recognize the water level and start to agitate and function properly so I could get some laundry done?
The digital timer keeps flashing the code o6. i start a load of was and it seems to go thru the cycle but the timer goes back to the original start time. the wash doesn't get finished
Posted on Mar 13, 2009
Unplugging the washer has NOTHING to do with this problem. This is probably a water inlet valve problem. A very simple fix, that most consumers can do on their own. Variables? What variables? The common sense issue here is that ALL the water settings do the SAME thing. Since you have ruled out the fill hose, a water inlet valve would be common to ALL settings.
Posted on Sep 06, 2008
    Novelist:
  • 166 Answers
Peace,
All of the above should be true!
But I recommend having hands on service , because there are to many variables!
Try unplugging the machine for 5 minutes and then restarting it and see if it is a reset situation!
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Kenmore Elite HE3 has power but not starting wash.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t code problem
check your water supply make sure that you have both hot and cold water on at all times. Pull the hoses off and see if the screens on the water valve in the back is clogged.
Aug 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso 21082
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Whirlpool Calypso GVW9959K Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
