Question about Microsoft Windows Vista Ultimate Edition
PRINT SPOOR SERVICE PROBLEM IN VISTA
i am getting this problem in all vista systems.
print spooler service is not running in vista system.can u help.
Click start-->run -->type services.msc--> u would see the list of services ---> find "print spooler " ...make sure it is "started " ..or the like possiblity is that u may have installed the printer drivers that came along for xp. .....is so , disable "lexbec " under services list . ........and reinstall/ dowload the vista drivers from your printer vendor site .
Posted on Sep 10, 2008
Printer spooler
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Mar 13, 2011 | Canon Office Equipment & Supplies
Tip
PRINT SPOOLER PROBLEM ON XP/VISTA
Resolution:
on May 21, 2008 | Epson ACULASER CX11NF All-In-One Printer
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Spooler
Click please
Start, in the white search box, type run, in the run box type
net start spooler
note the space between the words
you should be good then
Regards
Richard
Apr 27, 2009 | Microsoft Windows Vista Ultimate Edition
Print spooler not running on Windows XP
Just click "Start"
"RUN" ant type "cmd" this brings you to the command prompt window.
In here just type " start_spooler" and press enter this should start it for you!
Mar 30, 2009 | Microsoft Windows XP Professional
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
Mar 15, 2009 | HP DeskJet 3745 Printer
Cannot get Microsoft works to open in vista
If you stop the print spooler service...that should allow Works to open up.
  1. Open Computer Management.
  2. In the console tree, click Services.
    Where?
    • Computer Management/Services and Applications/Services
  3. In the details pane, double-click Print Spooler.
  4. Do one of the following depending on the task you want to do:
    Click Stop to stop the service.
    Click Start to start the service.
  • To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
  • When you stop the Print Spooler service, it might stop other dependent services.
  • The print spooler runs under the Local Computer system account by default.
  • You can also start and stop the Print Spooler service through a command-prompt command. For more information, see Related Topics.
Mar 09, 2009 | HP Pavilion dv9000z Notebook
HP 4355
First we need to know which operating system you are using.
If you are using XP. Then follow the below steps to refresh the spooler.
Click start-->run-->type services.msc-->locate print spooler in the services window and right click on it and click stop and then click start else simply click restart or refresh and then try to print.
If you are using Vista, then perform the below steps.
  1. Click Windows (c01330063.jpg ), right-click Computer , and then click Manage . The Computer Management window displays.
  2. Double-click Services and Applications , and then click Services .
  3. Double-click Services .
  4. In the right pane, right-click Print Spooler , and then click Properties .
  5. On the General tab, in the Service status section, click Stop and then click Start .
Jun 05, 2008 | HP Officejet 4355 All-In-One InkJet...
Microsoft Windows Vista Ultimate Edition Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
