Question about Akai CTS2550 25" TV
No color i only have a black and white screen on the tv. the menu will not come up. as with the volume bar, the mute bar. nothing shows up on the screen except for a black and white screen.
    Problem Solver:
  • 7 Answers
CHECK THE SYSTEM IC
Posted on Sep 09, 2008
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
My GE 35GT695 has lost color and will only show in black & white. However, when I press the menu button the menu shows in color while the screen is still black & white.
the on screen graphics are sourced from red,green ,blue drives,..your fault is with the colour decoder .sorry it is a repair that needs a expert engineer ..it could be dry jointed to test for dry joints try tapping the back cover or bottom of the set ..good luck farr64[colin]
Dec 29, 2009 | GE 35GT695 TV
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Jun 11, 2008 | Samsung Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
Akai CTS2550 25" TV Logo
140 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
