SOURCE: Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
SOURCE: Ricoh CL3100N
I've noticed that sometimes in "Page setup" (assuming it is a MS word document you are printing), there are two columns under the "Paper" tab. the left column is the paper source for the first page and the second column is for all following pages. Ensure both columns are set to auto tray select or tray1/2.
My understanding for the second page to ask for paper is either:
1/ what is mentioned above,
2/ the second page is not an A4 size document (mixed size pages).
hope this helps.
