Question about Gigabyte GA-945GZM-S2 Motherboard
Motherboard crash Hello, i have a problem about repairing my motherboard. Problem that: When i press power button there no any action. I tested my ATX by myself, it is working. I can change any part of motherboard (transistor, pin, condensator) of my motherboard, just help me please. My mail is: trecords2008@hotmail.com
  • egsarma Dec 17, 2008
    I had the same problem. Initially a delay was there. later smoke came out from smps. I donot know what to do. Is it a problem with smps or motherboard?
    egs
  • 700 Answers
Check your power supply. Do cord accidentally disconnected?
Do you use small AVR? Could it be choking the CPU of power. Check CPU power supply if it ok.
Next thing to check. Cpu unplugged and power off. Ram, video card, PCI card isolate the problem one by one until you get the fault. Or test it to another unit if you can.
Changing motherboard component is impractical actually like transistor.
Posted on Apr 05, 2009
  • fougzki Apr 05, 2009
    To egrsarma:
    If it is on motherboard better to replace the whole motherboard. Hope no other component has been damaged like cpu.
    If it is on the power supply replace the power supply. But I think some other component is also damaged. If you have no other spare to test have it check to a repair shop.
  • 739 Answers
Many power supplies have two(2) four lead connectors, be certain you have the right one connected to the upper left side of the cpu. The next place to check would be at the switching pin out at the bottom right of the MO board, if your switch block is unified, it may be a different configuration than the pin out. if this is the case, then you have the option to rewire the leads into paired blocks. Pain in the backside, but doable. if you cross the pins of the switch block one pair at a time you should be able to locate the power on comibination, the imprint on the board isn't always accurately applied.
Posted on Jun 04, 2009
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
Micro ATX motherboard ATX case?
Two possible causes - either you have installed it badly and it shorts to the case (take it out of the case and try it there) or not all the necessary cables were connected (check especially the power cables and the power button).
Jul 13, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
Compaq 120694-101 Motherboard would like to totally upgrade
Your PC case will hold any atx motherboard with 4 or less expansion slots. Just about everything made now will fit. You will have to replace your power supply if it still has the standard factory unit installed. The newer boards require an ATX power supply with the additional 4 pin plug for extra power to the CPU. Go to newegg and look for combo deals, they run them all the time. Here is a gigabyte board that is very nice. GIGABYTE GA-MA78GM-US2H Micro ATX AMD Motherboard image-3300643-10440897
I hope this solution helps you out.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Compaq 120694-101 Motherboard
Motherboard
i believe your motherboard is already bad. have it replaced.
Sep 13, 2008 | Gigabyte GA-945GM-S2 Motherboard
Just Bought The Mach 4 tried to test it with current power supply
Hi, one quick thing you can check is to see if the cable running from the power switch is plugged onto the right pins on the motherboard, it will most likerly say (pwr btn) next to the pins or something like that, it may also need to be a certain way round.Let me know what the outcome is if no good we can try something else. hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 18, 2008 | Pine Technology Mach 4 KT400ANB...
Mother Board problem
Are there any beep/s sound that you can hear when you try to Boot your desktop? If there are none then do some check the following: 1. Please check if you have properly connected the connectors for ATX 20 pins powersupply and for ATX 12V Power Connectors. 2. Press the POWER Button to turn ON your Desktop and Check if the Powersupply FAN is spinning to ensure that there is Electricity power for your Powersupply BOX. Then press (approximately 5 secs) the Power Button if Turn Off again. If its shutdown then your motherboard is OK. But when you press the Power Button and you hear a sound like a BOAT's Horn/Fogging sound then your Power Supply is not sufficient to provide power to your Desktop or CPU.. 3. If you got 2 or more memory Cards installed in your motherboard then try to install those Memories one at a time. To determine if one of those card is defective..
Apr 08, 2007 | ASUS P5ND2-SLI Deluxe Motherboard
Gigabyte GA-945GZM-S2 Motherboard Logo
163 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
