Question about Panasonic TC-15DT2 15 in. TV/DVD Combo
A/V Jacks The message "connect your a/v jacks" will not go away. I have checked the physical connections and there is nothing disconnected. No matter what I try the message will not go away. It's very annoying because it sits in the middle of the screen.
5 Suggested Answers
SOURCE:
SOURCE: Input/Output Connections
This model Panasonic is a monitor. Component video, S-Video, and audiio connection ports are on the bottom of the unit. Once the unit is wall mounted you can hardly see them, hidden behind the front leading edge of the case. Two speaker connection terminals are found
slightly above the bottom edge at extreme left and right. The main power button is also on the bottom left.
Posted on Jan 03, 2008
SkinWill
  • 148 Answers
SOURCE: DMR-ES10....no image on tv screen
Try connecting the recorder with the yellow composite connector and make sure your tv is set to that input it may be that your tv says "dvd" but it is trying to use a different input then you are connected to. Some tv's have multiple video connections for one input, they should but not always detect which you are connected to. Make sure the input you are trying to use has only one connection in use.
Posted on May 24, 2008
daniel719
  • 240 Answers
SOURCE: Scrolling message will not go away
press play for 5 sec/ should shut off
if not
try with no tape in press play and rewind at same time for 5 sec
hope this helps.
thanks,
daniel.
Posted on Jan 13, 2009
SOURCE: Base appears to be shorted for phone connection.
I have same problem but it will happen while I am in middle of talking. handset will go dead and say it is not connecting to base, but base indicates line is in use. I try it with other handsets to no avail
Posted on Apr 17, 2011
EL52500 Phone base & 4 handsets have static, message Line in Use. Bought new phone, charged, connected - it says no line. Have dial tone at phone line into house.
Sounds like your phone has a short. If you see the message "line in use" call your number, is it busy, now unplug your phone and call your number again, is it ringing? Indicates a short, possibly in your equipment. As for message " no line" is the electric connected to the phone and did you check for dial tone in tat particular jack with a known, working phone first...just to make sure there's dt @ the jack. Good Luck :)
Nov 19, 2015 | AT&T Lands Phones
Why does my panasonic cordless home phone have the error message "check tell line?"
I like to use an old corded phone to diagnose telephone line problems. First though, try a new telephone cord between the base and the phone jack. (This can be obvious to some but I once saw a person swap a handset cord (the coiled cord) and an RJ-11 cable.)
Next plug a different phone into the jack. If it gets a dial tone, the KXTGA470B needs service. (If it is out of warranty, it may be better to replace it.) If the second phone does not get a dial tone, try the spare phone at a different jack if there is one. If the phone gets a dial tone at this jack, your wiring to the jack or inside it is faulty. I'd check the jack first, unscrew the faceplate and look at the back of the unit. There are two types of jacks. One has all of the conductor wires connect to screw terminals. If any wire is broken, strip the shielding from a bit more of the wire. Then wrap the wire under the appropriate screw. The other type of jack is a keystone. If a wire is loose, you'll need a punch-down tool (available at many hardware stores in the wiring section). Do not strip the wire, just press a new section into the correct point on the keystone. See http://www.lanshack.com/wire_phone_jack.aspx for the pin assignments.
If there isn't another phone line jack or there is no dial tone at another jack, find where your telephone service comes in. Open the box and look inside. If you are lucky, the service will have an RJ-11 connection. Plug in your test phone and check for dial tone. If there is still no dial tone, call your phone company and tell them to fix it. (I've had mice chew wires in underground service.) It will be a free repair. If there is a dial tone here, you've confirmed an inside wiring issue. One thing to check while you are at the box: since you have multiple jacks, check that all of the wires connect to the box. We had our service upgraded and they forgot to wire one jack to the new service box. (It was obvious when we went to the box; the wire was just floating behind the house's vinyl siding.)
Next consider your service type, if you have DSL with your phone service, check the filter. Some phone companies have these inside the home and you are responsible for it. Lightning strikes nearby can damage them and interrupt the phone line. Otherwise, since you didn't see any breaks in the wires when you inspected them, you may want a professional to check the wiring. It's possible to have one broken conductor within the shielding. (One way to test this is to swap the wires at the service box and the jack. Most RJ-11 lines are 4 or 6 wires. Two wires are needed for each line. Use the diagram I linked to above and physically connect the R2 and T2 lines to the R1 pins.) Some telephone companies will do indoor repairs for a fee.
If the service box doesn't have an RJ-11 connection or you have an outside DSL filter, ask them to send someone out to physically check the service. (Just because their computer says it is up, doesn't mean it is. I've seen it happen.)
I hope this helps.
(My preferred test phone is an old rotary unit. It never fails unlike some newer phones.)
Aug 01, 2014 | Panasonic KXTGA470B KX-TGA470B KX TGA470B...
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
All three were working but 2 of them quit suddenly and say "Check Tel Line". The one that still works is plugged directly into modem. The 2 that say check tel line will work if i plug them into modem just...
This phone system should only have one physical phone jack connection as all the handsets are wireless. It sounds like you may be getting your phone service via your Internet Service Provider. It would help to know how you are connecting your home telephone wiring to your equipment.
Oct 29, 2013 | Uniden DECT1560-3 DECT 6.0 Expandable...
When I try to play a dvd through my sony bravia, it comes in black and white. No matter what I do on resetting the factory specs, it stays black and white
Check and RE-SEAT the VIDEO connections on BOTH the DVD Player output jacks and TV input jacks (re-seating means remove and replug). Poor connections can cause this, especially if using RBG cables. Make sure DVD R (red) is connected the TV R (red), and the same holds true for G (green) and B (blue) jacks & cables. The G & B cables & jacks can look very similar in dim light. Do the same thing even if using HDMI or SVGA cables.
I hope this helps & good luck!
Sep 20, 2011 | Sony Televison & Video
Don't know how to hook up my router kids unpluged.
This is an easy fix. The back of the router has a single power jack and 5 jacks for network cables. 4 of the jacks are grouped together on one metal "plate" and are called LAN or "Local Area Network" jacks. The 5th jack is removed from the others slightly, and is by itself on its own metal "plate" closest to the antenna. This jack is called the WAN or "Wide Area Network" jack.
Disconnect the power cord if not already unplugged.
The WAN jack (closest to the antenna) should be connected to your DSL or cable modem output with a cable long enough to stretch between the two.
The LAN jacks should be connected to the computer(s) network jacks in your home that do not use a wireless connection.
Once everything is connected, turn on the DSL or cable modem (if not on already). After 30 seconds, power up the WGR614. After 30 seconds, you should see the power light on, the test light (a check mark) should be off, the wireless light (the antenna) may be on or off (depending if you configured it to be on before) and the internet light should be on or blinking (it's the icon next to the "1" light). If the internet light is off, check the WAN jack and cable back to the modem and make sure the modem is on.
After the internet light is on, turn on the wired computer(s). The 1, 2, 3, and 4 lights will flicker when computer(s) are on and connected to the 1, 2, 3 or 4 jack(s).
I hope this was helpful!
Oct 26, 2009 | NetGear WGR614 Wireless Router
Only DVD works
rca jacks may be goin out, one of our did that and i had them replaced for under 20 bucks, jason
Dec 13, 2007 | Zenith B25A02Z TV
Panasonic TC-15DT2 15 in. TV/DVD Combo Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
