Question about Whirlpool Calypso GVW9959K Top Load Washer
Water backflowing through the detergent fill valve
There are various symptoms with this washer. Initially, I got a 'CE' (Communications Error). I cleared that but then, when I tried to start the cycle, the water valves would open and I could hear water flowing but it would only run for about 10 - 15 seconds and then stop. It would stay like this for about 10-15 seconds and then start flowing again for about 20 seconds and would then stop again. Then it would not start up again without 'Cancelling' and beginning the cycle again. It would then repeat the previous cycle that I described above. There was some water in the tub but I noticed a lot of water on the floor so I raised the top of the washer and started the cycle again. I noticed that when the water begins its fill cycle, the water will leak out through the detergent fill line.
  • swiley312 Sep 06, 2008
    Thanks for the feedback. Can I check for voltage at the solenoid to determine if the valve is being 'demanded' open by the control module?
  • swiley312 Sep 10, 2008
    The service repairman just left after I declined to have him repair the washer. It would have cost $563 to repair a three year old $850 machine. What a piece of junk. I will have some parts to sell off this thing. Is anyone interested?
  • 750 Answers
Its like I said, sometimes it's not worth putting good money into bad.
Try speed queen .com
They have a commercial washer and dryer with the best warranty in the industry and they are tested at doing 8 loads a week for 25 years.
Almost a no brainer!
ngafm
Please give me a solved rating before you sign off
Posted on Sep 11, 2008
    Novelist:
  • 166 Answers
You have a cycle error and need hands on service!!
Bets to make the call and get it done right!
Please rate me at our site before you sign off!
Thank you!
It's not always a easy cure!
Posted on Sep 06, 2008
  • N Golan
    N Golan Sep 06, 2008
    You have to put that back out on the site!
    I'm not sure!
Washing machine is showing IE
If you have a LG washer, the IE error indicates an inlet error. This can be caused by low water pressure, the water shut-off valves being in the closed position, clogged filters (either at the shut-off valves or the filters on the washer), an anti-flood inlet hose failure or a problem with the washer's inlet valve. First, make sure that the shut-off valves are open. Next, shut off those valves and disconnect the fill hoses. Check and clean the filters on each side. Try new hoses. (Many anti-flood hoses will restrict the flow when they fail. A way to check this can be to connect the hoses to the shut-off valves and put the other end into a bucket. Open the shut-off valves and check the amount of water flowing into the bucket. Do this for the hot and cold side separately.) Make sure that the inlet hoses are not kinked.
Make sure that the end of the outlet hose isn't lower than the washer's fill level. This can lead to the water flowing out of the washer as it fills.
If none of these solutions work, then the inlet valve has failed in the closed position or there is a problem with the sensor that monitors the amount of water in the tub within a certain amount of time. Try replacing the inlet valve. (If you add a comment with the washer model number, I may be able to get the part number for you.) Of course if the washer is under warranty, contact the company.
For a Samsung washer, this could be a Suds error. That suggests too much detergent was used, a non-HE detergent was used, or the filter before the drain pump is clogged. Try running the washer without any detergent to rinse the excess detergent out. If the error recurs, get a bucket ready to catch the water from the tub and pump. Next you will need to get into the washer and separate the drain hose from the pump and clean out the "coin catcher" filter. Make sure that there are no foreign objects in the pump. Then reconnect the hose and try running the machine. (If you add a comment with the model, I may be able to tell you how to access the pump.) Other causes for the IE error are a bad door seal or the outlet hose being too low in the overflow pipe. Also check that the washer is level and that the detergent drawer is fully closed.
I hope this helps.
Dec 17, 2014 | Washing Machines
Code ce and lf
If there is any breakdown in communication between the machine controller and the motor
controller, “CE” flashes and the unit beeps once.
Some common causes of “CE” errors include:
• Conformal coating on serial communications pins between the machine controller
and motor controller. After disconnecting power to the unit, try scraping this coating
off the pins.
• Check the resistance values between the serial communications pins with the
connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked
up properly or a “CE” error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display
If the water fill time exceeds ten (10) minutes, the water valves are turned off and “LF” is
flashed.
Press STOP/CANCEL to clear the display.
Aug 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer hums, starts to fill with water, then
Dec 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Starts filling than stops than start filling than stops and a code come up saying CE OR LD
Apr 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Machine doesn't dispense detergent
Here's a few suggestions you can try. First, open the dispenser tray far enough to where you can see inside. Enter diagnostics mode by selecting DRAIN SPIN, NO SPIN and pushing ANY button under OPTIONS 4 times (it has to be the SAME button, though). This will enter the washer into diagnostics mode which checks the hot and cold water fill functions, the dispenser tray functions, tumble, spin and drain. Watch inside the dispenser tray to see if you can see any water flushing through the various compartments (detergent, bleach, fabric softener). The water should be fairly steady and forceful. There's not much else, besides gravity, that forces the detergent into the wash tub. Now...if you don't see the desired water flushing action that you should see, check the overhead portion of the dispenser cavity. Pull the tray all the way out for this. There are a series of holes where the water is forced through. Sometimes these holes become clogged and will not allow enough water in during the fill and rinse cycles. It's usually the fabric softener side that becomes blocked, though. You can take some cotton cotton swabs and perform the tedious task of cleaning each hole if they are blocked. I've had to do this before and it does fix the problem. The other possiblities are the fill valve not allowing enough water pressure through (but, you didn't mention anything about a slow fill problem), or a kinked or blocked hose coming from the fill valve. If you wish to check the fill valve, turn the water off and remove the hoses from the back of the washer. Check the inlet screens for clogs. If you have hard water, well water, or BOTH, it is common for the inlet screens to get accumulated with sediment. Again, some cotton swabs will clean the majority of the sediment from the screens (you can use a little white vinegar as well). If you wish to check the inlet hoses from the fill valve, remove the top of the washer by removing the three torx screws along the back of the washer. The top will slide back then lift off. There are a series of hoses from the fill valve to the dispenser. Check to see if any of them have become kinked. I hope this information is helpful to you. Post back with comments if you need further assistance.
Jan 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
