Question about Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range
I have a viking rangetop and the griddle's gas is not turning on the glow plug works fine but no gas seems to be coming out.
  • 59 Answers
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Posted on Mar 11, 2009
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Viking griddle flaking
I have the same thing happening with my Viking griddle. I have nearly the whole top seasoned to a jet-black state - and it is stick free!! Now up near the front edge the coating/seasoning is chipping off. I've just been taking the loose chips off and not worrying about it too much, it maybe the size of a half dollar at this point. The front edge of the griddle is the hot spot on mine; and I've learned to adapt my cooking techniques. My guess is the hot spot on my griddle is responsible for the flaking...
Mar 25, 2012 | Viking Kitchen Ranges
I have a Viking Professional VGRT Gas 4 Burner + Griddle Cooktop. The griddle stopped working all together. The burners still all ignite and work fine. The griddle does not heat up. When we turn the...
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Jul 29, 2010 | Microwave Ovens
Griddle makes backfire noise
I get the same sound but I found it is actually coming from my stainless steel backsplash, it seems like the heat makes it flex from time to time.
Jul 10, 2010 | Viking VGIC485-6G Gas Kitchen Range
Viking Griddle thermostat issue
replace the hotplate ignitor. you may in the future have simmilar problems with the ovens or broiler, there are 4 ignitors in my unit I have replaced each at lease once. it seems to be a weak link in the design. If you need more information contact c2d6c2 at yahoo
May 27, 2009 | Viking VGSC306-4B Gas Kitchen Range
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
I have a viking cooktop with 4 burners and a center griddle. The griddle will not hold heat. It fires up then goes out.
This can be cause dby one of 2 problems.
When you turn the control to turn the Griddle on, does it come immediately or do you have to turn it a long way before it comes on?
If it turns on immediatly then it is more than likely the Ignitor
If you have to turn it a long way you have a defective Thermostat
Feb 18, 2009 | Viking VGRT600-6G Gas Cooktop
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Nov 21, 2007 | Viking VGSC366-6B Gas Kitchen Range
Open Questions:
Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range Logo
204 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
