Question about JVC XV-S200 DVD Player
Power Light shuts off
The power light is on but goes out when "open" is pressed. Light comes back on after power cord is unplugged and plugged in again. Nothing on the unit works.
    President:
  • 3,130 Answers
That is a fault in the power supply My friend Wish i could be more help
Posted on Mar 31, 2006
SOURCE:
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
LG shut off by itsself last night Comes on but, green light flashes a couple of times, makes a clicking sound red light comes on then shuts off. The tv also, turns on if i manually press the channel button...
Tries unplug,replug the tv back like an hour later.The tv,now it will resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Try website Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | LG 50PC5DC 50 in. Plasma HDTV
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Turning on i guess
It should work OK once you plug it back in. Note there are three places to check the power connection.
- The power pack has to be inserted firmly
- the cord that goes into the power pack
- the cord into the wall - be sure to check the wall outlet with a lamp or something to make sure it's not an overall power problem/breaker, etc.
Steve
Sep 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
Unplugged Hood power cord
YES THE POWER BEING SHUT OFF THEN ON WITHOUT THE LIGHT SWITCH BEING INTHE OFF POSITION BLEW YOUR LIGHT BULB. IT COULDN'T BE ANYTHING ELSE UNLESS YOUR CORD HAS A FUSE. CORDS WITHA FUSE ARE FAT AND ODDLEY SHAPED AT THE END U PLUG INTO THE LIGHT.
Sep 10, 2008 | Sunlight Supply 400 Watt Hps Sunsystem I...
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Cannon BJC 80
5 times try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
3 times, probably something wrong with the cartridge.
Nov 21, 2007 | Canon BJC 80 InkJet Printer
JVC XV-S200 DVD Player Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
