Question about Hoover Vacuums
Access to panasonic mc e450 electrical supply panel
Hi
Trying to access the electrical box section of the above. Can see three screws in total, (2 inside at front and one at rear) but panel still does not seem to want to budge. There is an obvious simple wiring connection failure, but access is proving difficult. Any advice welcome.
Disconnect powe
Remove three screws
Tap base of handle from front - it will then slide back
remove handle
Pivot bottom of cover over electrical box up and it will unclip from the top edge.
Posted on Apr 07, 2010
Well, I've got the same problem - mains cable has a loose connection but I can't find a way to open up the electrical panel. Did you ever find a solution
Posted on Oct 13, 2009
2 Suggested Answers
SOURCE: Panasonic MC-E450 vacuum cleaner wiring connection access
Disconnect from power first!!
Undo the three screws.
Tap the base of the handle assembly from the front and it will slide back so it can be removed
With the handle removed, pivot up the bottom of the electrical box cover and it will unclip at the top edge.
Panasonic Vacuum MC-V7395 to replace the foot release pedal do I have to remove the belt and other things to get to it?
On most of the uprights I have worked on, the top cover has to be removed to get access to the release mechanism at the rear.
Apr 26, 2016 | Panasonic MC-V7395 Vacuum
How to fix panasonic mc e450
The thermal fuse for the motor is inside the motor on some models or screwed to the motor case on others
Aug 08, 2014 | Hoover Vacuums
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Where are screws located that access main motor compartment in panasonic canister MC-V9647? Something is rattling inside and smells hot. Belt or motor?
If the model is the same as pictured, the screws should be visible.
If the model is older like I think it is, the screws are going to be a tad tough to get to, but not impossible.
First you will need to take the bag door off. Open it like you would to change the bag and then push the bag door back farther so that the hinges "pop" out. Generally how i do it is put it on the counter, with the bag facing you, open as far as you can, grab the top portion of the bag door and push it back quickly.
Now, when the bag door is off, with a flat screw driver, the colored housing above the gray bumper will come off. insert the flat screwdriver in there and pry it open a touch. do that to the other side as well. Once both sides are open, you want to slide the screwdriver towards the back of the unit and gently pry the back off.
under there you will find 2 screws (if you need to go that far at this point) and you can remove the back of the unit easily.
Good luck,
Mark
Nov 08, 2010 | Panasonic Kenmore Canister Vacuum Vacuum
Mar 01, 2010 | Panasonic Vacuums
Removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
Trying to replace the mains cable on uproght cleaner mc e468,but having great trouble getting the plastic covers off
first remove handle
single screw rear of cleaner and slide handle horizontally rearwards
remove access cover (2 screws) for electrical connections and switch
Aug 09, 2008 | Panasonic Vacuums
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Need to open motor compartment
Use a flat blade screwdriver, The dusy compartemnt door will come off by pushing it back, it just pops out. Then the rear top cover is held on by a tab, one in each corner. Put the flat blat in the slot at the bottom of the cover and work it until it pops loose. Then there are 2 screws to tak out to remove the cover over the motor and cord reel asm. But now you can get to the motor.
Jan 24, 2008 | Panasonic MC-V9620 Canister Vacuum
Vacuums Logo
197 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
