Question about Canon Office Equipment & Supplies
Cannon scanner 5200f puts what look like scratches along one side of scanned slides and films
A friend and I found the calabrate buton and after hitting it the images scanned without the lines. Thanks
Posted on Sep 07, 2008
My canoscan 8400F suddenly stopped working last week. I had been scanning slides thru Photoshop when on my next scan attempt, I got this message: Cannon scan for these reasons: -The original may not...
You have to remove the white protective sheet from the the lid. Once you remove it you will be able to scan film. Also make sure the lock button is not in the lock position.
Open the Canoscan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left
Another thing is this can be caused by a faulty FAU cable. One or more of the eight wires within this cable has fractured
Oct 16, 2010 | Canon CanoScan 8400F Film Scanner
Edge Of Scan Overexposed
If the slides are ok , and not overexposed themself, brown discoloration on the side means a problem with the scanner lamp.
Oct 05, 2008 | Nikon CoolScan V ED Film Scanner
My scanner sometimes crops a particular slide but not others. Some scan ok. What is going on?
Be sure to put the slide in the holder in the proper direction. The opening in the slide holder is rectangular, not square like the slide. If you place the slide in the holder horizontally and the holder window is vertical, it will crop off the sides of your picture.
Jul 20, 2010 | Plustek OpticFilm 7200 Film Scanner
Negative or positive option is not available on drop down menu on select source on ScanGear CS so how do I scan film? I am trying to scan 35mm film on my Canon 5200 F scanner using ScanGear. The manual...
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
Jun 24, 2009 | Canon 5200F Flatbed Scanner
Unable to scan b/w neg's correctly using Digital ICE
Unfortunately, you cannot use Digital ICE on B&W films due to silver particles contained within the film. The Digital ICE future only works with C-41 (negatives) and E-6 (slides) processed films, but not B&W films.
Jan 16, 2009 | Nikon CoolScan V ED Film Scanner
In your expert opinion, what is the best all in one soloution (regardless of vendor) for printing, cd/dvd printing, scanning 35mmslides and copying. Thanks.
A lot of different people aee these questions and answer the ones that they choose to answer.      Consumer reports, in their November issue,  rated the Cannon PIMA MP 610 as the number one pick for value for the money. From researching the printer questions on here,I personally I would stick with a big name brand.  I am still using a panasonic tractor feed printer from 1980 something along with an Epson Photo printer. I jsut purchased the Canon that I told you about to give as a present. My thoughts only.
Jan 04, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Scanner
The Canon CanoScan 8800F is an excellent scanner and will do what you want. The scanner driver includes a descreen feature which is to reduce the Moiré patterns that are common when scanning items such as magazines or other printed materials. This scanner is capable of scanning 35mm film negatives and positives including mounted slides. It is also capable of scanning 22cm x 6 Film Strip (120 roll film). There is zero warm-up time on the lamp. This means that the scanner is ready when you are. Other scanners may require 30 seconds to a minute or so to warm up.
Here is a link to the product page for this scanner.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=15561
Hope this helps.
Jun 12, 2008 | HP Office Equipment & Supplies
I have a CanoScan 5200F
Because the slides are see through which means you will need a special add on for the scanner for it to support slides. If you have this already then make sure that it is fitted on properly so no light can get in the compartment where the slides are held during the scan
Jan 12, 2008 | Canon CanoScan 4200F Flatbed Scanner
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
old marine
old marine
