Question about Yamaha RX-V390 Receiver
Yamaha rex-v390 My son's yamaha rx-v390 will not stay turned on and the display is dim. No audio output at all. any suggestions? THX, DP
    Novelist:
    Champion:
  • 277 Answers
Modern home-theater components monitor themselves electronically for potentially dangerous malfunctions such as damaged internal parts. When a unit's microprocessor senses a problem, it will typically shut down so that no further damage -- or potentially dangerous disasters like fire! -- occurs. Your receiver is identifying something upon turn-on and shutting down as a result. My guess is that you're going to need service for your Yamaha. There's likely no fix that you're going to find. You need a professional service technician.
Posted on Dec 12, 2005
My rx-v390 will not turn on, only the red LED is turning on...
Sounds like the power transformer is dead. Would have to go in for repair
Jan 04, 2013 | Yamaha RX-V390 Receiver
Rx-v390 when i trun on power after few second auto shut off.. what could be the problem I changed all Fuse (4A 125V) still have same problem.
The problem is with either the Amplifier or the Speakers.
If you disconnect the Speakers and then turn back on and get the same fault then it is the Amplifier.
If it stays on OK then you need to turn off again and connect one Speaker at a time (turning off again between each one) until you find the fault Speaker.
If it is the Amplifier thats faulty then it could be a simple repair that would involve replacing some Capacitors but you would need a Soldering Iron and the knowledge how to de-solder and re-solder components to a PCB.
If you need any further assistance then just ask.
Jul 04, 2011 | Yamaha RX-V390 Receiver
I want to connect my DishNetwork HD receiver to my Yamaha.
Use Digital FiberOptics to connect them best sound you can get one at radioshack its as simple as pluging it into the back of each device it will not plug in wrong
Jan 11, 2011 | Yamaha RX-V390 Receiver
Connecting a subwoofer to a receiver without subwoofer out jack
Does your receiver have any kind of line level audio output? AUX OUT, LINE OUT or similar? If so, you might be able to send that a subwoofer. Most standalone subwoofers have their own crossover and level controls built in, so you can make adjustments there.
Mar 11, 2010 | Yamaha RX-V390 Receiver
My Yamaha RX-V390 receiver when volume turns up it turns off
Does it display something on LCD? Maybe you have connected speakers with wrong impendance and the receiver is overheating.
Check the impedance of speakers, it should be at least 6 ohm. Also check the receiver manual if it has settings for impendace (6 or 8 ohm).
Feb 01, 2010 | Yamaha RX-V390 Receiver
My yamaha rx-v870 won't stay turned on more than a few seconds when i press the power button
protection is turned on,it is a seriously damaged,only service can fix it.Probably output transistors are defect,one or more
Nov 24, 2009 | Yamaha RX-V870 Receiver
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Yamaha RX-V390 Receiver Logo
564 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
