Question about Sony DSC-T7 Digital Camera
Small dent on lens cover
I have a small dent on the lens cover. Whilst it does not effect the use of the camera it is annoying me every time I look at it!!! It seems that if I could remove the cover - I may be able to gently push out the dent from the revers side. Anybody know how to detach the lens cover without breaking the camera?
    Novelist:
  • 130 Answers
Put a sticker over it or a little stripe or somthing. The cover looks like its connected on the inside of the front case. Contact sony maybe they will send you a little slony logo sticker? you know how their logo is little dots? maybe you can find one on e-bay or somthing. Stickers cover everything :P
Posted on Apr 03, 2006
SOURCE:
How do I un-freeze lens of Samsung i-Function lens, which is stuck on approx 43mm?
Still your lens is defect. Could be a gear or the motor, or anything inside. You can't solve this yourself. when it is in warranty and it has nothing like a small dent or scratch, just return it to the shop, or visit a samsung certified repair centre close to you.
Feb 08, 2015 | Samsung Cameras
I slipped while hiking and sat on my Canon PowerShot SC 210 IS which was in my back pocket (dumb). The shutter cover now does not fully close nor open. I can move it open with my finger, but it will not...
HiNo, yours is not screwed if any other camera function work.I would like to help you. Could you photo the dent area and post here. After that I can help you.
May 26, 2011 | Cameras
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Apr 28, 2010 | Olympus ? Stylus 500 Digital Camera
Camera model SL620. Lens cover does not automatically fully retract. A small portion blocks the top and bottom of the lens but will retract if touched. Tried blowing dry air on the cover and wiping with a...
Apparently the lens has had some kind of impact to cause the lens cover to be bent a little. What happens is that the lens cover holder , or ring, on the end becomes bent or misshaped to a degree. This then causes a binding effect on the diaphragm assembly.
What I have done is to very carefully (while using good magnification) pry up on the edges of the lens cover metal edging on the inside edges. This will release the pressure on the lens cover diaphragms.
But, be advised that this is can harm the lens cover more, unless you are extremely cautious. That means to use a small screwdriver or some such tool to pry up on the inside edges carefully.
Also be advised that too much pressure can cause the whole ring which holds the diaphragm assembly together can pop up and off. Then the whole assembly can come apart, and that is very hard and can be tedious to put back together.
Apr 15, 2010 | Cameras
I dropped my camera, the lens cover is stuck open
To fix the lens is probably not your kind of work, and now you may be better to sell this camera for parts on a site like Ebay.
Not a good idea to try to fix it.
Sep 11, 2009 | Panasonic DMC-TZ5 Digital Camera
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
My pentax optio 50 lens got stuck half-way and now the camera turns on briefly and then goes off automatically. I've replaced batteries and pushed the lens in manually, but it's still not working. Mary
This is tricky .. if you have no warranty, and have already managed to push the lens in.. I suggest pulling the lens outwards gently AS you simulataneously turn the camera on. You may be able to use a small suction-cup affixed to the lens to do this :)
you could hold the lens-cover open with tape so the cover is less likely to be damaged.. good luck, this problem is common, annoying, and usually not worth repairing (*although with some cameras it can be done again and again!)
Aug 30, 2009 | Pentax Optio 50 Digital Camera
Olympus Stylus 600/Digital 600 6.0 megapixel
Hi
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Sony DSC-T7 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
