Question about Sony KP-61HS10 61" Rear Projection Television
I have a 2000, 61" SONY rear projection TV model
SOURCE:
techman
  • 3130 Answers
SOURCE: WONT TURN ON
If you know how to trouble shoot solid state electronics and know how the curcuits work, then Im sure you can handle this repair. But my friend a tv set is not a place for a handy man to be experimenting around inside of, as there is alot of high voltage inside this set even when its turned off! Its best if you do not know all of the safty issues to seek out a pro to assist you in this repair. It could be a bad solder connection, or a bad filter capacitor that supplys the B+ to the video chip. Without looking at a schematic and tracing the circuit, its all a guess. There are no real user replacable parts inside this set. Good Luck PS please do not forget to rate this thread.
Posted on Nov 25, 2006
SOURCE: Sony TV, sound but no picture
thanks, I had someone here fix the big board. It seems that when we lifted it with the hand truck we broke the board. The unit is so heavy it is hard to hand carry upstairs. The repair was just under $200.
Posted on Jun 16, 2007
mistersony
  • 320 Answers
SOURCE: model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Posted on Oct 26, 2008
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 04, 2009
circuitworld
  • 335 Answers
SOURCE: Sxrd rear projection standby light blinking 4
check the bulb door and make sure its closed all the way. be sure the bulb is firmly pushed into its socket. if the problem is still there you may need to repair the power supply board.
Posted on Jun 17, 2009
Is there a self check on this Projection TV
It to my knowledge only has a error blink code---if comes on and or fails--look for the power light to blink a specific number of blinks.
If set comes on sometimes it may have the on screen feature but it has to make it on to try that.
Jun 13, 2012 | Sony Televison & Video
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Turning closed caption on Sony kp61hs10
Your power source seems to be the problem, you will need to replace that part.
Jul 18, 2010 | Sony KP-61HS10 61" Rear Projection...
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Convert my Sony kp61hs10 HD Ready to receive HDTV
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony REar Proj. mOdel KP61HS10
I may be able to help you figure this out. My specialty is Sony, mitsubishi and panasonic. Are you planning on repairing the TV yourself, Can you solder? Let me know .
Jan 13, 2008 | Televison & Video
Sony KP61HS10 Convergence issue
u may purchase service manuals here/
www.servicemanuals.net
Jan 09, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony tv will not stay on
unplug the unit for a couple of minute and plug it back in...if it still wont stay on get a repairman
Jan 23, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony KP-61HS10 61" Rear Projection Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
