Question about Acer PD100 Multimedia Projector
Acer projector my projector is green on the sceer
  • kristyd Mar 19, 2009
    Everything on the screen is yellow-green. We've tried resetting and the bulb only has 420 hours (suppose to get 2500)?????
  • monaco123 Mar 27, 2009
    My Lumens projector have the same problem most color are yellow no more white and blue color any solution for this?
    Problem Solver:
  • 53 Answers
A DMD has no inherent colour capability - it's just a configurable mirror array. If you want to do full-colour projection, then, you'd expect that you'd have to use three DMDs and three coloured filters - red, green and blue.
But if a single DMD's switched in synchrony with a rotating "colour wheel" - a spinning tri-colour filter that lets through red, green and blue light in turn - then the very rapid switching speed of the DMD lets it lay down red, green and blue images in such fast succession that the result is a perfect colour image.
You can do the same trick with a single LCD panel, but it's not a good idea; LCDs are transmissive, rather than reflective, devices, and block something like half of the light that tries to get through them. To maximise brightness in LCD projectors, a three-panel design works better. If you try to pump the entire output of a super-bright lamp through one LCD, keeping it cool becomes rather challenging.
The extreme smallness of the moving parts on a DMD mean that it behaves like a solid state device, not a mechanical one. For all their complexity, DMDs have very high Mean Time Between Failures (MTBF), and well-made projectors based on DMDs can be expected to last easily as long as LCD units, and probably longer. If a DLP projector fails, it's not at all likely to be because there's something wrong with the DMD.
Posted on Sep 06, 2008
Why is my youtube sceer green
Go to youtube and chose a video and when it start to loading press pause ,press right click on the video and untick on the first tab a choice that says hardware acceleration
Jul 25, 2014 | Microsoft Computers & Internet
Acer eprojection management
check out network configure
Apr 17, 2013 | Acer PD726W Projector
I have Epson Projector and Acer Laptop both with DVI connections. How do I connect a Nintendo Wi-fit consul so I can play and hear the games. I have a wireless sensor.
I've never seen a projector with DVI ONLY -- double check your projector and all compartments and see if it has any other inputs. The wii can use the regular composite, red, yellow, white output. The wii can use SVideo and the Wii can use component output -- red, green, blue video and red/white audio. I do not think there is a DVI cable for the Wii.
Mar 09, 2010 | Nintendo Wii Console
My acer mininotebooks goes on hibernating
check to see if your power cable is bad. if it went bad your computer would go to hibernate to save energy, then shut down all together. see if when you plug in your power cable if your computer shows that its charging. if it does maybe its a bad battery.
Jul 13, 2009 | Acer Aspire 5100-5022 Notebook
How achieve maximum resolution acer projector
When you connect a source to the projector, the unit will match the resolution input to it. As long as you don't exceed the max resolution, which is considerable, the unit will display it. Go into the menu and select auto-image to have the projector give you the best quality image. Hope I helped you!---Rick
Jul 08, 2009 | Acer X1160Z Projector
ACER PH530 COLOR WHEEL
http://www.mk-electronik.de/hersteller/PDFDokumente/Acer/Projector/PD520.pdf
Aug 27, 2008 | Acer PH530 DLP Projector
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Acer PD100 Multimedia Projector Logo
548 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
