Question about JVC HD-52G786 52" Rear Projection HDTV
Fuzz on the inside of screen
How do i clean the inside of my new HD-52G786
    President:
  • 3,130 Answers
MY gosh we have some techs that dont know what d-ila is???? ok folks just for you. Technology Overview & Description The D-ILA device, a special LCOS technology developed by JVC, is a reflective type of LCD that delivers a greater amount of light than a transmissive LCD panel and is comprised of groups of pixels which correspond to each image dot. Also, unlike conventional LCD panels (in which the switches and electronics are mounted on the same surface as the pixels), the D-ILA 's driving IC substrate is located behind the liquid crystal layer. Because of this, the ?screen door effect? found in many LCD projectors is eliminated almost entirely, leaving a nearly-seamless picture which is very impressive. D-ILA and DLP will be battling it out for the next several years, something that will undoubtedly be good for the market and will result in some excellent "trickle-down" technologies for the home theater user. And IPGMAN call a pro on this DO NOT TAKE THIS SET APART as you could poop off the video drivers off the ribbon cables if you take it apart wrong.. Call a pro ofor youe own good!!! Good luck proinfo@jvc.com
Posted on May 25, 2006
Hog wash. If you look there are little doors on each side of the tv half way up. Take the doors off and have someone hold a vacum sweeper on one side while you take a can of air for cleaning computers and blow out the dust .If you notice there is a projector lens down in the middle shoot the air on it . I just did mine other day. Couple little dust bunnies can make world of differance.
Posted on Oct 07, 2008
    Problem Solver:
  • 12 Answers
DONT FORGET TO CLEAN THE LENS ON THE OPTICS, AN LITTLE SPEC. WILL MAGNIFY. I SUGGEST A HANKY OR MICROFIBER CLOTH
  • sean wolf May 25, 2006
    TO ACCESS THE OPTIC AND MIRROR, TAKE BACK OFF. YOU MIGHT HAVE TO REMOVE THE LAMP AND DOOR AS WELL. DON'T FORGET TO MARK YOUR WIRES. (DONT TOUCH THE GLASS ON THE LAMP) CLEAN THE MIRROR AND OPTIC LENS. YOU SHOULD BE GOOD
    Novelist:
    Champion:
  • 277 Answers
You should be able to remove the back cover from the set. You may have to remove screws around the connection area too, as this will be connected to some sort of board inside. I would certainly caution you about power issues, make sure the set is unplugged. Once removed,in most big screens you will now be exposed to a mirror,(the mirror will often be attached to the back cover you removed) and you will see the 3 "guns" red/blue and green. If you are unsure of what to use to clean, go to any quality camera store, find out what they would recommend to clean expensive camera lenses with, this should be safe for the mirror and lenses inside the TV. Obviously you do not want to use anything that could be abrasive. Some sets, like Pioneer, you will want to enter from the front, by removing the screen, this will give you a chance to clean that too. For someone that is comfortable with what they are doing this should take about 1 hour. Good luck.
Posted on Dec 12, 2005
How to clean inside screen of jvc big screen tv?
I would not even attempt that If I was you on this model, what is dirty, spider webs or what?
Dec 08, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Can't get volume on jvc hd 52g786
This set is prone to the audio board inside failing---all the audio is on one board, last one I replaced was just over 100 dollars.
Oct 30, 2012 | JVC HD-52G786 52" Rear Projection HDTV
My jvc hd-52g786 does not recognize the remote. What do I replace?
The set has a receiver inside that the remote transmits a infrared signal to--if remotes known to be good do not work on set the receiver is bad.
May 28, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Our son put cleaning solution on the projection tv and now we have a large blotch on the tv - how do we repair this ?
Sorry this problems can't repair,the tv screen panel itself the black film high gloss plastice coating has been bleach out,now u just have to live with it or have to buy another new tv.Try buy another exact tv from JVC corporation directly,should have some percentages discount for returning the damage tv to them.
Mar 02, 2011 | JVC HD-52G786 52" Rear Projection HDTV
Shadow like effect on television screen. What could be the cause? What is the resolution.
http://download.sears.com/own/05754845.pdf
http://www.user-manuals.com/advanced_search_result.php?keywords=HD-52G786+service+manual&forward=plist
http://209.187.238.153/movies/ServiceManual.pdf
Please find above your user, top, parts, below, and be,low that is your service and repair manual. this should allow you to isolate your issue. It may indeed be a problem with your projection unit, but as these problems can have many many causes, use the TS manual to help isolate.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
My jvc HD-52G786 TV channel will freeze then
most likley you need to see ure dealer about that as it cost to buy the program and the cord just to do an update every 2yrs
Apr 27, 2010 | Televison & Video
Brown picture
you can clean it, take front off and clean with a mild detergent. if this tech has any relatives in the auto mechanic industry stay away and keep your women away!!
Dec 11, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Spot on JVC hd-ila screen
There are several things that could be causing this. Dust or foreign matter on the inside of the screen, dust or foreign matter on the reflecting mirror or dust in the optical block or light engine. The first two can be fixed by you if you can gain access to the interior. The third will require a technician. If you have had your question answered, please be sure to rate the solution. Thanks!
Oct 26, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Apr 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
383 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
