Question about HP Office Equipment & Supplies
Set up did not finish - HP Office Equipment & Supplies
  • 1,031 Answers
Are you setting it up as anetwork printer check if you miss out any of the following steps and restart the setup
Setting Up a Network Printer
1. Click on the Start button, then click Control Panel, then click Printers and Faxes, then click Add Printer.
2. A new Add Printer Wizard window opens. Click Next to start.
3. Select Local printer attached to this computer. Make sure Automatically detect and install my Plug and Play printer is NOT checked.
4. Then click Next to continue
5. We will create a new port for your network printer. Select Create a new port.
6. Beside Type of Port, click on the down arrow, then click on Standard TCP/IP Port.
7. Click Next to continue.
8. A new Add Printer Port Wizard will open. Click Next to continue
9. You must now type your printer's IP Address in the Printer Name or IP Address field.
10. The Port Name will automatically be filled when you enter the IP Address. Do not change the Port Name.
11. Click Next to continue.
13. IF YOU DID NOT HAVE PROBLEMS, Windows XP will scan the network to find your printer's IP Address. This may take a few seconds. Select Finish to continue
14. You must now select the printer's manufacturer and model. Windows XP will automatically select the detected manufacturer and printer driver. Normally, you will not have to change this selection.
15. OPTIONAL: If your printer is listed but you have more than one printer model to choose from, please select the model with PS, if available.
for example Select HP and then 8750/8450/8150 and click Next
16. IF your network printer is NOT automatically detected, select the Windows Update button to find the proper software drivers.
17. You will be prompted to confirm the selected printer driver. Make sure Keep existing driver is selected, then click Next to continue.
18. You will be prompted to assign the printer a Name. You can use the default name, or add more info to indicate the printer location, such as My Office, Hallway, Foyer, Room 222, etc.
19. Select Yes if you want to use the printer as the default printer. Click Next to continue.
20. You will be prompted to share the network printer. Do NOT share the network printer.
21. Click Next to continue.
22. You will be prompted to print a test page. Select Yes, then click Next.
23. Check your network printer to make sure your page printed. Select Yes when prompted to confirm a successful test page.
24. Click on the Finish button to complete the Add Printer Wizard.
Posted on Sep 06, 2008
Ive attached the finisher unit to the canon clc3200 how do i set
do you have correct finisher? On these macine you can have two finishers atached. FinisherM-1 and FINISHER N1/Saddle finisher N2.
Is these hapend on installation of new finisher or it worked before?
Check that wright slot for connection is connected.
If you want service manual for finisher send me mail on emma.servis@gmail.com
Jul 12, 2010 | Canon CLC 1150 Color Copier
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
Finisher setting will not work
touch the additional functions key then touch custom settings scrolll till you find limited function mode touch it then turn limited function off turn copier off then on this should turn the finisher back on unless the finisher has an error
Sep 25, 2009 | Canon imageRUNNER 5000 Copier
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Mailbox ,finisher xerox dc12
i take you have a mailbox finisher. If so the finisher is plug and play with the dc12
Jul 02, 2008 | Xerox DocuColor 12 Printer
Staple function is grayed out - how do you turn it on.
You do n ot need to enter the Service Tech code to ajust finishers. In fact that code should rarely be entered.
Is the option available while copying?
If it in the driver, select the greyed out option and let the driver inform you of the problem/setting.
Has the finisher been identified in the "instaled options" tab of the driver?
Normally, the driver or panel will indicate what the conflict is if any. If all these have been set correctly, contact whomever installed this finisher and have them do it properly.
Apr 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Printing with just finish cartridge
You need to print it in spot colour mode.
Click Click File-> Print, and when the print dialogue pops up, click Properties. In the printer driver dialogue that opens select Spot Colour, click the Spot Colour button, select Finish (Glossy Finish) and print.
Sep 25, 2007 | Alps MD 5000 Thermal Printer
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
