Question about Intel Motherboard
Recognize sata hd
Should i just manually input HD properties?
why was the sata dvd player not recognized?
    Genius:
  • 1,027 Answers
OK, you did not say that it was a DVD driver - in the BIOS, SATA settings should be auto. If it is not seeing it after, then check the mother board spec if it is SATA 1.1 or SATA 2. Most drives have a jumper that is left on for SATA 1.1, and removed for SATA 2. If it still does not work, then the drive may be bad.
Posted on Sep 06, 2008
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
HDMI problem
u must go to the inputs and tell it you have an hdmi on the yamaha
Feb 03, 2009 | Yamaha RX-V663 Receiver
Receiver will not recognize a 5.1 input
Have you selected the digital input through the audio setup? You can assign different digital inputs to various video inputs and this may solve the issue
Jan 17, 2009 | Onkyo TX-NR905 Receiver
I have a Hp dv2000 and HD isn't recognized as master, even slave
Be carefull,be sure that your hardware is mark in hardware compatibility list on the model unit which is using.
Dec 29, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
JVC KW-AVX815 Player USB Source does not recognize 2.5'' HD
i got my portable drive to work by partitioning to 127gig fat 32 only the old fat32 not the vista version it wont read above that or recognize files if you make it larger
Nov 19, 2008 | JVC KW-AVX810 Car DVD Player
Toshiba HD-A3 won't load HD-DVD
It should recognise the discs. If you just bought it new, it's under warranty. Take it back and exchange it.
Geno
Mar 05, 2008 | Televison & Video
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Toshiba hd dvd A20 remote codes
i am having the same problem with the HD-A2KU hd dvd player not recognizing any of the codes. it seems that the dvd player does recognize the codes but will not control the player. when i click the on off button the dvd player changes to a word but does not turn it off or control it.
Oct 30, 2007 | Toshiba HD-A20
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
