Question about E-Machines Computers & Internet
Power supply fan not turning - E-Machines Computers & Internet
  • 1,031 Answers
Check the power cable to see if there is power supply,if yes then check the output voltage from the power pack where the power fan is housed for supply if no output then the power pack is bad and need s replacement
Posted on Sep 06, 2008
    Sergeant:
    Champion:
  • 331 Answers
Try to   see the smps
or maybethe fan is not working........
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
Computer won't turn on.
There must be a problem with your power switch on your computer casing, or motherboard or power supply.
Detach your power supply and try this, to check if your power supply really works. If the auxiliary fan will turn, your power supply is good
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-0.jpg Testing your power supply and motherboard as seen on photo
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-2.jpg If the cpu cooling fan and power supply did not turn the fan, but you have checked already the power supply that is working then you can conclude that your motherboard is need to be replace. But the power supply and motherboard and working, meaning to say your computer casing need to be replace or try fixing the contact of the switches attach to your casing.
Have a good day.
Apr 04, 2015 | Dell Studio Xps 9100 Desktop Computer
Error code 5351
Motor Failure
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Voltage not going to cpu
Not sure just what you mean. If your computer is plugged into the wall and the power is turned on, the power supply should be on and the cooling fan turning. Also, the CPU fan should be turning and the hard drive should spin up.
Note that the power supply is the main component that must be supplying the power. If you don't hear or see the fan turning in the power supply and the little power light on the front of the computer does not light, replace the power supply.
If your power supply is running and nothing else is running, I would unhook all devices and leave just the CPU and video and memory in. If you get nothing, then the motherboard is probably bad.
Sep 22, 2011 | Computers & Internet
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
I have a Okia 420ATX power supply. I had it
Based on the additional information that the power supply fan turns on for a few seconds and then goes off indicates to me you have a motherboard or processor problem. I would have a service center check the computer for you.
Feb 03, 2010 | Okia 420w UL Approved ATX Computer Power...
Fans on back & bottom aren't worcking
If there's nothing wrong with your power supply or fans, on may newer computers is a temperature sensor and the fans will turn anywhere from not at all to full speed, or anywhere in between. You do want to make sure that your processor isn't overheating, however, just in case your fans aren't working. Belarc Advisor (do a google search) is a free program that will give you all sorts of info including temps if the bios supports it. (most do)
Jan 15, 2010 | Codegen computers6: 450 Watt PC Power...
Pc power supply 20 + 4 sata 400watt if i plug the mains lead into it with out it being pluged into the motherboard will the fan in the power supply work ?
No it needs to be plugged into the moterboard for the switch wire to turn the fan on. if your looking to have the fan run while the power to the pc is off you'll have to mod the power supply, there are loads of websites that can help with this be carefull tho power supplys hold a lot of power for a long time after they've been turned off and unplugged.
Sep 14, 2009 | HP HEC HP400D 400W ORION HP400D ATX 12V...
I have a okia 500atx power supply. When I attempt to turn on the computer, it will stay up for about 3 seconds then turn off. is the power supply the problem?
CHECK THE FAN REMOVE ANY DUST AND SPIN THE FAN PLUG IT IN AND TURN IT ON IF SAME PROBLEM THAN THE FAN IS BAD IN THE POWER SUPPLY AND YOU NEED A NEW POWER SUPPLY TAKE IT WITH YOU WHEN YOU GO TO THE COMPTER STORE FOR A NEW ONE
CANDYMANGANDY
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Audiovox FPE3000 turned off sponataneously and will not turn back on
I would suggest getting a schematic of the set and using a multimeter looking at the power supply test points to determine what is happening exactly with the power supply.
Sep 08, 2007 | Audiovox FPE3000 30 in. HD-Ready LCD...
Computers & Internet Logo
221 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
