there will be bars underneath the seat that are supposed to go across to unlock both sides so that the seat can move forward and back, try having someone pull the lever and see if you can see from behind the bar that moves and figure out what it corresponds to on the opposite side. you should be able to move it by hand, release the lock and set the seat where you want it, as for a permanent fix, most seats are not difficult to remove, typically four bolts, although some take specialty tools like large torx bits, and i would imagine the bar is replaceable
YOU HAVE A SWITCH OR A TILT ACTUATOR MOTOR PROBLEM. LINCOLNS HAVE 5 OR 6 ELECTRIC MOTORS MOUNTED ON THE UNDERSIDE OF EACH FRONT SEAT WHICH REQUIRES REMOVING THE SEAT TO INSPECT .THEIR ARE ALSO CABLES ATTATCHED TO THESE MOTORS SO LISTEN WHEN YOU HIT THE TILT SWITCH DO YOU HEAR A MOTOR NOISE? IF YOU DO THEN YOU MAY HAVE A BAD CABLE.
It maybe a coin or something trapped in the seat rail or pull cord snapped or stuck if manual, if electric then have you checked plug to motor or fuse???
There is a little green plastic clip that is attached to the cable and pull lever, if you trace from the pull lever and cable to mechanical lever then to bottom of the frame it is on the bottom half of the seat, you will see it once you flip up the seat bottom over , on the black metal frame is where the clip is at, towards the bottom and facing the other seat frame that your not flipped up. well anyways the green clip is probably broken, or the cable came undo( which I doubt) the clip is a weak point in the seat mechanism , you wont be able to find it a retail automotive stores, dealer item only , that's if they even carry it anymore, or you might try a junk yard and look around for another excursion seat or a f250 or super duty and use that one. I've heard that you might be able to use the American door lock clips plastic hardware, they are suppose to look alike, but ford wont tell you that. The kit is at AutoBodyToolmart .com Part # 9914 for about $26.99 , that's what I heard. Good Luck !!!
Sometimes coins or other items get stuck in the track. Might have to remove the seat and try to free the track. If all looks ok, unbolt both motors and move to a more desirable position.
If my research is correct, I did find that the decklid latch mechanism is released by a cable. The cable probably has stuck in the cable sheath, due to years of neglect, (Failure to periodically lube the cable. Hint/hint)
You need to manually release the decklid mechanism. Now bear with me, as again, my 'Vette's are older, ('70 and '76), and their seats tilt forward.
If you can tilt the passenger seat forward, perhaps you can get in there and lube this cable through it's sheath. (Use penetrating oil at first. I would then remove the cable, and clean it, then lube it, after getting the decklid open. Lube? White Lithium in a spray can)
Then try to pull the latch mechanism in the direction the cable would pull it, to release it. (The cable may be broken?)
Yes! Whoever does this feat of magic, of getting to that decklid mechanism, will look like a contortionist! Hit the jacuzzi afterwards! lol!
Most often, the stuck steering wheel is a result of a faulty 'tilt relay switch.' If you attempt to use the tilt switch and you can hear a clicking/whirring noise, then its your relay switch, if not, it may be the motor that is broken.
Replacement parts and labor could run $200 + from the dealer.. Yes, a replacement switch can be obtained from a salvage yard, BUT NOT from an auto parts store. It is not difficult to remove old switch and replace
I have the same problem. Seat and steering column just stopped working. Passenger side normal. No fuse for these components. With so many postings witht he same problem there has to be a defective or worn out source. Please post if you find a solution!
