Question about Xerox WorkCentre M15i Laser Printer
M15 scanner Hi, I am service engineer for office automation products.I mistakely crosschecked the main pcb of M15 to M15i machine.After refitting old M15i main pcb ,it starts to scanner lock as scanner moving right side . I hope you will help in this issue soonest.
  • pmbajra Sep 10, 2008
    Tryit
    Thank you for your suggestion,But I crosschecked main pcb ,it seems ok.As you said there may be fault in the ribbon cable plug of main pcb.Hope to get more solution.
    President:
  • 2,072 Answers
That sounds more like the ribbon cable has some bad ends. remove the white ribbon cable from the board and see if some of the metal contacts are peeled back.
I have seen that problem a few times. The ends of that cable are not made to be taken out and in very many times.
Posted on Sep 08, 2008
  • Rick Kasper Sep 10, 2008
    Most likely that ribbon cable needs replaced. It WILL cause that problem.
Density adjustment
isbcomputer.com is a dedicated online store offers Printer Spare Parts, Formatter Card, Main Board, Power Supply Board, Flat Cables, Fuser Pressure Roller, Gear, Sensor, Scanner Units, HDD Parts, HDD PCB, Hard Disc Drive Spare Parts, Data Recovery, Refilling Products, Jet Image, Toner Powder, Toner Drum, Toner Cartridges, Laptop Accessories, Power Adapters, Computer Accessories, Computer Services, Computer Peripherals and many more Computer and Printer related products at one place with best prices.
Visit - http://isbcomputer.com
Dec 30, 2016 | HP LaserJet 1320n Printer
CODE ERROR 100 SHOVING IN I R 3300 CANNON XEROX
You may need to replace the laser, it may have failed, this is from the service manual
E100
0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec
after the generation of the laser drive signal.
0002 While the laser is ON, the BD signal cycle is outside a specific range 20
times or more continuously.
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific
range 20 times or more.
Main cause The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The
laser scanner unit is faulty. The DC controller PCB is faulty.
Action
1. BD PCB
Try replacing the BD PCB. Is the problem corrected?
YES: End.
2. Laser scanner unit, DC controller PCB
Try replacing the laser scanner unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
anual.
Aug 30, 2014 | Canon IR 3300 Digital Copier
I miss my office 2007 product key
take it
KGFVY-7733B-8WCK9-KTG64-BC7D8
enjoy :)
Feb 18, 2011 | Computers & Internet
Need assistance with sending faxes
Can you explane your problem in more detail. We can resolve it, but what exactly cant you do? Can you receive and not send? If so, move the phone cord to the slot marked LINE not the one that says EXT or Phone. If you have a digital line, it will not work. An M15 requires an analogue line.
You have a good product there. let me help you get it working as you want it to,.
Nov 11, 2009 | Xerox WorkCentre M15i Laser Printer
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
CANNOT GET INTO THE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
Once you press menu #1934 you have to then press the machine status button then scroll to maintenance, then scroll to clear memory. Once you do that repeat entering the tech mode, press machine status, maintenance and perform a shading adjustment with 5 pieces of paper on the glass, that will recalibrate the scanner.
Unable to print to the Xerox m15i with mac OSX
Xeror does not list a Mac driver for this unit. There is a Xerox Global print Driver, which supposedly "drives " all Xeror printers. But again I do not know if it will work on Mac's.There is a phone for this driver support @ 18773626567
http://www.office.xerox.com/latest/SFTBR-15.PDF
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Oct 08, 2008 | Xerox WorkCentre M15 All-In-One Laser...
Printer is very slow
In machine settings there is a setting for the USB port , it has a fast and slow setting.
The M15 technically is not a intended to be a network printer.
You can look into hooking it up to a pocket pro device which is a small print server.
There are other products that you can use to set up that, way.
Apr 24, 2008 | Xerox WorkCentre M15i Laser Printer
Ink toner problem?
No, that is not the ink, That is a fuser problem.
The fuser needs to be replaced.
It is a very easy repacement. Cost is between 170-200 dollars if you don't have a service agreement.
One of the two rollers in the fuser has a problem and is not making good enough contact to fuse the image.
Jan 10, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i Laser Printer Logo
241 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
