Question about BenQ FP71G 17" LCD Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up? Monitor gives several colors(blue,red,yellow,white) and goes blank wen turned on
  • 1 more comment
  • rob_matthews Sep 14, 2008
    my monitor will go into standby after a second of turning it on ,is there a resistor i can bypass to stop it from going to standby
  • treborino Sep 29, 2008
    Samsung SyncMaster 174v. Monitor is about 5 years old. Problem just started. After about 1 or 2 seconds after turning on, the screen goes blank and the power light stays on. This problem now happens all the time.
    Is there a fuse or something I can fix?
    -help
  • Anonymous Oct 11, 2008
    I have the same monitor and is labeled as BENQ Model No. Q7C4.
    The monitor goes BLANK as in Black Screen but the power LED is on.
    I have at time got the screen going by either unpluging the the screen leads and reconnectioning them about 1/2 a dozon times while the power is still on. Once it fires it stays on until it's turned off again. Can you help please.
    Sergeant:
    Champion:
  • 331 Answers
The moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Posted on Sep 06, 2008
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Monitor is blank/dimension 2400
If you put a spare monitor on your computer and everything is fine I'd say it has an electronic problem. If the screen is still blank I would look at the video card or PC itself as the problem. Just for fun check the video cable for bent or missing pins.
Mar 23, 2009 | Computers & Internet
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
there is an hardware issue in your lcd it needs to change one of the capaciter please take it to a lcd technician
thanks
Jan 24, 2009 | Acer AL1715 17" LCD Monitor
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
687 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
