My toshiba lcd flat screen model 27w l56p has lost all red colour. The tv is not too old 3-4 years
I heard you can get red plasma refill at best buy, im having this same issue
Posted on Sep 15, 2008
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
Colour on the tv is too green and red model 26av502U. Less then three years old. Reset to factory default settings per manual instructions and it didn't work
If you are using component cables change them out. It sounds like they're faulty. Try another device like a dvd player on a different input with different cables to see if the picture is still too red or too green. If so then the tv needs servicing. If not you can rule out the television.
Aug 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
I Bought Toshiba LCD TV Model 32A3000E 3 years ago, now when we switch on for approx 2hours the LCD screen distorted with green and red colour and getting worse. The next day it is ok again and here goes...
If the tv tend to operate when it gets warm this cause a thermal intermittent problem, common cause is the cold solder or loosed connection try to check the main pcb or the power supply solder side of the board then try to observe if there is cold solder or slight cracked to the lead try to solder that part. Note before opening or removing the back cover of your tv, be sure to unplug it first to avoid serious injury. Or try contact a service repairman to do it for you to lessen the stress. good day hope this may help.
Jul 13, 2011 | Toshiba Televison & Video
We have a 52" Toshiba
This problems is not the causes by a human or an objects by hitting the LCD screen panel wright?If,yes this problems can't be repair,the LCD screen panel it dead.The tv now,only can be used as spare parts,not worth as a whole tv anymore.If tv it develope all these colors lines by it self?Yes,this tv can be repair,the board call the T-Con decoders board is the causes and the problems.This T-Con decoders board sit right at the middle botton of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Dec 03, 2010 | Toshiba Televison & Video
Brand new Hannspree 28" tv when you switch it on screen just changes colour white to red all colours and nothing else
Get rid of this model!!!! The Hannspree and Toshiba models used a TFT LCD screen from a chinese manufacturer that has put out faulty components for the last 3 years. The Problem is in the way the Active Matrix Screen was manufactured. I would recommend you return this item immediately to the place where you purchased it and pick a different brand; also stay away from Westinghouse!
Sep 24, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
