Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he 3 front load washer
My washer won't drain heavier loads. It will drain if there is just clothes in it, but add a towel, forget it! I get the f2 error, which occurs and the end of the rinse cycle when it has about 4 minutes left. I have checked for blockage in the hoses and see nothing. It is about 6 years old.
  • 5,911 Answers
Have you checked the drain pump reservoir? This is a common point where debris collects and causes slow drain and no drain issues with this washer. The following link provides guidance on how to check:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you have checked the drain pump, have you checked ALL the drain lines? The drain line that leads from the bottom of the wash tub to the inlet side of the wash pump is another common area where items get stuck. Its also an area that most consumers forget to check. I have found small articles of clothing such as wash cloths, underwear and socks, stuck in this hose causing slow drain problems. NOTE: It is recommended that you use garment bags for small items).
If you verify everything and still have the "F02" Long Drain error, it is recommended by the manufacturer that you replace the drain pump. If anything has been in the drain pump for any length of time, it could potentially damage the pump impeller and/or motor. The pump may be running, but it may not be pumping.
I hope you find this information helpful. Let me know if I can assist you further.
Posted on Sep 06, 2008
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Blue stains on clothing
Brand New. Call for a warranty call asap. Should be no soap build up that quick.
Jan 28, 2009 | Kenmore Elite 45986 Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Laundry
Same problem with my front loader. You have to make sure to clean out the rubber trap in the front regularly. it seems to collect alot of hair and plug the drain hole. also it helps to leave the door open when you finish washing to further reduce the stagnant water smell. Use fabric softener for the towels!
hope that helps.
Aug 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Robert Rankin
