If this machine is running XP, or earlier (98, 2000, ME, etc.), beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine, or don't try to get on the Internet with this one.
Remove side panels, "2 screws on each side at back" top piece should come off, Normally the front panel is clipped into slots and possibily one to two screws, remove with care.
Check your video card connection.Be sure you have set the default monitor in the BIOS settings.If it still doesn't work. Try to install a video card because your motherboard maybe faulty.
try to check the wall power outlet if have power output, if have ,try to check the avr if the led lights up if not try to check the fuse of avr maybe its busted, if not, try to check the power cable that used to plug to system unit if have power output use multitester and if have, replace your system power supply.
Press F8 just when you start the your PC and enter in to the safe mode if it can run on the safe mode then do as below ( Start your PC with a boot-able CD and try to check if it possible to recovery the OS , )
Robert, I recommend you to open the chassis cover and check if there is any obstruction of any air vent. Meanwhile, if you can hear a loud fan spinning of the CPU heatsink, you might have to replace the thermal paste, the instruction http://www.techpowerup.com/articles/overclocking/134.
If the problem still persist, don forget to come back here. I will try my best to help you.
