Format how do i format my hp computer that has vista
  • Anonymous Dec 06, 2008
    Hi I have no windows xp system and iwant to formet xp and install agin xp with recover all old programs and datafiles.
    Problem Solver:
  • 53 Answers
Hi ,
it's so simple to format the hp computer , here are the steps :
http://www.webopedia.com/DidYouKnow/Hardware_Software/2005/harddrive_format.asp
Posted on Sep 06, 2008
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I HAVE A COMPAQ HP DX6120 AND I DON'T KNOW HOW TO OPEN THE BIOS . I NEED TO FORMATE MY COMPUTER AND I HAVEN'T CD BACK UP THANKS FOR YOUR HELP
You can get into the BIOS using the F2 or the DEL button. You need to keep tapping it as soon as you turn the computer on.
To Format the computer you would need an Operating System Disk. Like the windows XP /Vista /Windows 7 disk...
You need to boot from any of these disks and then you will be able to format the computer.
Nov 18, 2010 | HP Computers & Internet
Need CD to Format my HP COMPAQ Presario CQ50-21OUS
hi sir..There's a formatting option available during the install. Just boot from the Vista CD and select the partition where the old installation is. Windows will do the formatting for you. if you don't have vista you can download it from the following site and then boot your system
http://www.softpedia.com/get/Others/Signatures-Updates/Windows-Vista-Service-Pack-2.shtml
Feb 10, 2010 | HP Compaq Presario CQ50-210US Notebook
I GOT HP Pavilion dv 6915nr.... with windows
Hello
how did you format you computer? if you didnt delete the recovery partition you can start recovery to press F11 when bios starts.
HP should also be able to send you recovery disks for vista.
Im sorry to say but warranty doesn't cover formatting the disk, that is not a hardware failure
May 12, 2009 | HP Pavilion dv6000z Notebook
My hp laptop cannot detect network after it was formatted.
you will need to find out what wireless network card you have installed ( make and model ) and then go to the manufacturers website and download the relevant windows vista driver which will need installing or install the drivers from the installation disc for your laptop.
Apr 15, 2009 | Microsoft Wireless Network Adapter Xbox...
Installing windows vista on compaq presario 750 computer stops responding during installation now can't boot or startup
Vista installations inbult drive format tool is not so good, and causes errors, so i recomment u format the drive with some linux live cd's or some other bootup type partition tools. Then do a clean install. The problem should be solved if u hav min system requirements for vista.
Mar 21, 2009 | HP Compaq Presario F750US
After upgrading to a new computer with Vista, the ocr not working
Check the HP web site and see if they have an updated driver for your AIO printer that will work with Vista
Mar 19, 2009 | HP PSC 2355 All-In-One InkJet Printer
Having problems printing with hp 2355 and windows vista format
go to www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Jan 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
Vista and yahoo voice compatability
ware can i get voice for vista at plese
Jun 19, 2008 | Logitech 250 Headset
Computers & Internet Logo
267 people viewed this question
David Payne
David Payne
