Question about HP Wireless Optical Mouse
Hp wireless keyboard 5129urf cant connect
Wirless mouse still connects.
have replaced batteries, pressed conect buttons in correct sequences, tried different usb ports, still nothing-
any ideas?
thanks
steve
  • mcea Sep 09, 2008
    I have the same problem with the 5129URF keyboard and mouse. It just doesn't connect. The receiver is inactive too. Do I need to use a CD to instll again?
SOURCE: Constant reseting of HP Wireless (P2360AA) USB Keyboard and Mouse Kit
check some Option Driver's control Panel system - Hardware - Device Manager - go to Keyboard's Up Date Drivers your Problem Solove ok
Posted on Apr 17, 2008
SOURCE: New HP keyboard & Mouse not working
I solved this problem by
1 removing the tower cover
2 taking out the small round lithium battery
3 taking out one of the memory cards
4 starting up, turning off
5 putting it all toghether again
6 presto, the mouse and keyboard works
Posted on Jan 26, 2009
  • 11800 Answers
SOURCE: hp 5189 keyboard connection problem
Dumb questions: have you put the batteries in the keyboard? Have you installed the drivers?
If yes on both then try moving the dongle  to a better position - an USB socket to the front of the case.
Posted on Sep 13, 2009
Testimonial: "The dongle is at the front of the pc, tried new batteries though.. Worked like a charm. Cheers for the help, silly of me really;)"
  • 72 Answers
SOURCE: My HP wireless mouse all of a sudden stopped
Try to completely shutdown your computer when you connect it and turn your laptop back on once the pc is already booted back up switch on the mouse...
Posted on Mar 28, 2010
SOURCE: HP 8159URF Wireless Keyboard Dongle lost!How can i use it?
Unless you can find not only the exact part number but a dongle with the exact same serial number its not possible.Having the same issue.I say shame on HP for creating this issue by not wanting to sell type specific replacements to resolve this problem.They would prefer that you buy an entire new set. Good Luck.
Posted on Aug 04, 2010
My hp wireless optical mouse stopped working, even with new batteries. please provide a DETAILED step-by-step process for resetting it. i know it involves pressing buttons on the bottom of the mouse and...
namastey!
*clean the bottom of a mouse and if the lens gets dirty wipe it with the soft dampened cloth
* replace the batteries
*Reinstall wireless drivers. If your mouse came with a CD, re-insert it into your computer's disc drive and install all software and drivers.Disable internal transceiver. If your wireless mouse connects to an internal Bluetooth transceiver, disable it using the Bluetooth utility in the Control Panel, and then re-enable it after a few minutes. Then try connecting your wireless mouse.
Aug 22, 2011 | HP Wireless Optical Mouse
Not conecting to computer
When you install a wireless mouse, first make sure your USB transmitter is plugged into a functioning USB port.
Then make sure the mouse batteries are fresh and installed correctly.
Once you are set, turn the mouse over and push the "connect" button on the bottom. Note: if your transmitter/receiver has a "connect" button, push that first.
Feb 22, 2011 | HP Wireless Optical Mouse
I cant connect the wireless keyboard or mouse
chaque battery of wireless KB. ok than refix USB port if it blue light is blenk ok, than back Side of KEYBOARD & MOUSE u have found one blue botton this botton press Same time press keybord button it will conect ok. the blue botton press only 5 Second
Mar 17, 2010 | Computers & Internet
How do I get my Dell wireless keyboard to work after replacing the batteries?
There should be a small button on the bottom of the wireless receiver and another small button on the bottom of the keyboard. Press the button on the bottom of the reciever first, then quickly press the button on the bottom of the keyboard. This is the connect sequence needed to connect the two devices.
Jan 07, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps, Bud
Jan 05, 2009 | HP USB Wireless Keyboard/Optical Mouse...
Keyboard will not connect!?!
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Hope this helps. Bud
Dec 31, 2008 | Logitech Cordless Desktop MX3200...
I plugged in my usb for my hp wirless optical moblie mouse and for some reason the light on the usb wont blink it just stays on I even press both the buton on the usb and the mouse that sais connect and it...
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 12, 2008 | HP Wireless Optical Mouse
Labtec keyboard quit working suddenly
Here is the sequence to connect keyboard and mouse to receiver:
Press Connect button on receiver, and within 10 seconds press the Connect button under the mouse. Wait 15 seconds. Then press the Connect button on the receiver and within 10 seconds press the Connect button under the keyboard.
-- Thatpat
Feb 25, 2008 | Labtec 9675120403 Keyboard
CANT GET WIRELESS MOUSE TO WORK
Try changing with a new set of batteries. also try to reset the connection of the wireless mouse and keyboard. you can locate a connect button on both the reciever and wireless keyboard. press both of them together and release them. this would reset the connection. try doing the same for reciever and wireless mouse connect buttons. this should work. also check for any possible alignment issues.
Jan 15, 2008 | Computers & Internet
HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Oct 04, 2007 | HP Wireless Optical Mouse
HP Wireless Optical Mouse Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
