Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
Quantum Fireball Lct20 20 GB
After 10 mins of using my computer it slows down like a baf engine.i think the hard drive is the problem.i installed windows xp sp2 on it several times formatting the hard and nothing...is my hard drive the problem?
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
A 20Gb Quantum Fireball LCT20 could be nearing its life end considering the length of time it has been in service. Perhaps what could be done is to perform a burn-in test on the 20Gb HD attaches as a Slave or Secondary on a 2nd PC or alternately, as an external mass storage device through an IDE to USB adapter. Burn-in test would be a multiple time scanning fro errors as those used by Norton Disk Doctor. Alternately, you can also Partition Magic to partition/format and eventually test the HD.
In your concern of PC slow down after 10 minutes, it is possible that:
  • the HD is slowing after some time or having difficulty searching for the called for system files;
  • heat related, either on the HD motor/bearings or even on the CPU (thermal throttling);
  • there are a number of software running in the background using the PC's memory;
  • presence of virus and/or malicious software.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 06, 2008
Well i have this Quantum Fireball lct20 40 GB for a while and i have no problems at all ecept for recently it is very slow loading up information. i scan disk it i checked the sectors of the disk and i...
I will make two comments.
1- make sure you have backed everything up you want to keep :-)
2 - a hard disk will appear to slow down as it fills up. it is actually running at the same speed but must work much harder to find space to place your data. if your disk is past 70% full you will probably notice a performance hit - if its past 90% full you will see a major hit. if it gets much more than that you run the risk of having real problems.
whatever the cause of the problem, the first thing you need to do is back it up. then make sure its not over loaded and if it is just get a larger drive. get your data over to the new drive and off you go.
Apr 01, 2017 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
I have a Snap Server which is close to 10 years old. Inside the Snap Server are two Quantum Fireball CX 3.5 Series drives. How do I tell the size of these drives?
> Quantum 13Gb FIREBALL CX
What is printed on the labels on the top of each disk?
What is the model-number?
Do a GOOGLE-search on that model-number, to see what others have written about that model,
including the "specifications".
Nov 13, 2010 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
I am looking for a Quantum Fireball 20.5 GB hard
The board alone is not available for sale. To recover the data you will need to buy a 20GB Fireball with same board and swap the control board.
You can buy a 20.GB Fireballl QMP20000AS-A from links below:
QUANTUM QMP20000AS-A - Buy Now at Cuetech, Inc.
QMP20000AS-A DELL 20GB 3.5" IDE 7.2K HARD DRIVE
Quantum QMP20000AS-A Fireball Plus 2 QUANTUM FIREBALL PLUS AS 20GB HARD DRIVE QMP20000AS-A -
Oct 22, 2009 | Quantum Fireball Plus AS (QMP20000AS-A)...
Just transfered hard drive to another computer - in setup- need to know capacity, cylinders, heads, sectors
The specs are:
Capacity (unformatted/formatted):
20.00 GB / 15.02 GB
Cylinders: 16,383
Heads: 16
Sectors: 63
Here is a PDF w/specs
Fireball lct15
(http://www.dll.com.mx/biblioteca/HDD/Quantum/Fireball%20LCT15.pdf)
Hope this helps!
Sep 11, 2009 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Jumper go`s in what line.if power out let it on my right handside
moz-screenshot.jpgHere is a picture I found that shows the jumper settings for:
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Apr 26, 2009 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Drivers download
Hard drives do not have an installation CD unless you are referring to Windows installation CD and installing Windows on the hard drive/
Dec 07, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
Quantum Fireball Plus 10.1 GB
Look halfway down the page for Quantum Fireball LM.....
http://www.tacktech.com/display.cfm?ttid=379
You will find the jumper settings there.
Nov 25, 2008 | Quantum Fireball Plus LM 10.2 GB ATA-66...
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
600 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
