Question about Sherwood RD-6108 Receiver
Sherwood RD7502 i want to connect waferdale subwoofer, but cannot pls. help
  • iowa468 Sep 15, 2008
    I know how to set this receiver up, but after disconnecting due to remodel and reconnecting..the speaker mode just won't hold the settings for either the speakers or the subwoofer. It also does not automatically go to the subwoofer mode as advertised in step 8 of the instructions. I can press it to get there (See step 9) , and change it to "Y" for subwoofer ...let it sit momentarily. Then when I check speaker setting, all is as it was - with subwoofer "N" and the speaker settings for small and large as they were before. All is plugged in as it was before with speakers and subwoofer. Too frustrating Any suugestions?
Yes, I am having the same problem and have been unable to solve it. I went so far as to replace the subwoofer and it still didn't work. I finally gave up.
Posted on Sep 24, 2008
I have the manual and I have the subwoofer hooked up correctly and the subwoofer is on. It worked before with this configuration..
I am concerned there is a short in the receiver since the settings won't hold? Anyone else have this problem.
It is not just the subwoofer settings not holding, it is the settings for the speakers.
Posted on Sep 16, 2008
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
RD-6108
Your sub woofer needs to have it's own power amp i.e. a "powered" sub woofer:
Assuming your sub woofer is powered & connect as shown then check the following setting:
Let us know how you get on.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 06, 2008
How do i wire up my sherwood rx-4105 reciever for a subwoofer
If the amp has no subwoofer channel then you take the right and left channels to the speakers and feed them in the subwoofer first, then out to the left and right speakers.
Oct 02, 2017 | Sherwood Audio Players & Recorders
Model rv6030r. How can I connect a subwoofer?
On those older model receivers there is no place to connect a subwoofer, you need to get some high quality 3 way floor speakers and use those, the crossover network in the speaker takes care of the routing of the low end signals to the woofer.
Feb 13, 2016 | Sherwood Audio Players & Recorders
I cannot seem to get the tv audio going through the amp, i have connected the red and white audio leads from the tv to monitor out, I've also tried connecting it through cd but to no avail. the audio...
You can't get ANY audio to work on receiver's Monitor Out (which is a component video OUTPUT intended for your TV, not an audio input from it).
Read the manual and get a handle on what those 3 jacks are for (page 6).
http://www.retrevo.com/support/Sherwood-RD-7502-Receivers-manual/id/2536ag207/t/2/
Then, if you really need audio from the TV (instead of or in addtion to the probable Cable/SAT Box that originates TV-related programming), just run the audio out from the TV to any available Line Level audio input. The Cable/SAT box is the BEST place for the BEST TV-related audio and it will be available digitally.
The TV's audio control plays a part in this, too. Find its menu and select a FIXED (or equivalent) setting so you can turn the cruddy TV speakers down without killing the audio output.
Sep 07, 2011 | Sherwood RD-7502
My powre subwoofer in not working with the sherwood r-945. Can you help.
I assumed that your receiver has a SUB RCA jack on the back..
find out the SUB output 1xRCA plugs of your receiver on the back and connect it to the 1x RCA input of your Sub...you just need a RCA cable .
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
If you need more help please contact me...with more detailed question..
Regards
Jun 22, 2011 | Sherwood R-945 Receiver
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
Sherwood home sub sp210 manual for speaker hook-up
pull sub out it may have been replaced and the speakers inside were not connected.
Apr 04, 2010 | Sherwood U8M Car Subwoofer
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sherwood RD-6108 Receiver Logo
301 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
